DirectAdmin 1.63.6 has been released
fln
Administrator
Staff member
Hi everyone!
We are happy to announce the release of DirectAdmin v1.63.6.
This release finally allows switching between ZeroSSL and LetsEncrypt certificates on a per domain basis (in Evolution skin only), it is also important to mention a deprecation of login-key usage counters (and limits) as well as security fixes.
Release Change log can can be found here:
DirectAdmin 1.63.6​
fln
I have installed latest version (update from 1.63.5) with after update I'm no longer able to access the "Licensing / Updatees" module.
Main menu is reloaded. At the right bottom there is a short notice " Error : Unauthorized". But that's only there less than 1s, not even possible to take a screenshot.
Logout and fresh login, even a reboot of the server didn't solve this.
Any support?
Maybe you are running highly customized skin? Please try switching to Enhanced or Evolution and see if the issue persists. In 1.63.6 release licensing information is now being rendered with new template rendering engine. It works fine with stock Enhanced skin.
If the issue still persists please open a ticket in the ticketing system so we could safely request access to your server and investigate the issue.
I have standard skin, nothing changed. And tried all other layouts and the Enhanced skin but gives same error.
It means issue is somewhere else then. Are there any errors in the DA service journal journalctl -u directadmin -n 100? Do you have any custom plug-ins?
The quickest way to resolve the issue would be opening a ticket in our ticketing system and providing access to the server.
As plugins I have:
CWAF 2.24.5
CSF
Custombuild
Output of journalctl -u directadmin -n 100
[root@server ~]# journalctl -u directadmin -n 100
-- Logs begin at Tue 2022-02-08 13:01:36 CET, end at Tue 2022-02-08 15:55:33 CET. --
Feb 08 13:01:49 server.***.com systemd[1]: Starting DirectAdmin Web Control Panel...
Feb 08 13:01:55 server.***.com directadmin[1459]: 2022/02/08 13:01:55  info license updated successfully
Feb 08 13:01:55 server.***.com systemd[1]: Started DirectAdmin Web Control Panel.
Feb 08 13:03:20 server.***.com directadmin[1459]: 2022/02/08 13:03:20 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:03:45 server.***.com directadmin[1459]: 2022/02/08 13:03:45  info license updated successfully
Feb 08 13:04:55 server.***.com systemd[1]: directadmin.service: Got notification message from PID 8761, but reception only permitted for main PID 1459
Feb 08 13:07:06 server.***.com directadmin[1459]: 2022-02-08 13:07:06 cwd=/usr/local/directadmin 2 args: /usr/sbin/exim -bV
Feb 08 13:07:07 server.***.com systemd[1]: directadmin.service: Got notification message from PID 9138, but reception only permitted for main PID 1459
Feb 08 13:07:09 server.***.com directadmin[1459]: 2022/02/08 13:07:09  info license updated successfully
Feb 08 13:09:13 server.***.com directadmin[1459]: 2022/02/08 13:09:13 Unsolicited response received on idle HTTP channel starting with "\n"; err=<nil>
Feb 08 13:09:20 server.***.com directadmin[1459]: 2022/02/08 13:09:20 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/comodo_waf/index.html?iframe=yes
Feb 08 13:09:52 server.***.com directadmin[1459]: 2022/02/08 13:09:52 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:11:56 server.***.com directadmin[1459]: 2022/02/08 13:11:56 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:12:09 server.***.com directadmin[1459]: 2022/02/08 13:12:09 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:13:25 server.***.com directadmin[1459]: 2022/02/08 13:13:25 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:13:28 server.***.com directadmin[1459]: 2022/02/08 13:13:28 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:14:30 server.***.com directadmin[1459]: 2022/02/08 13:14:30 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:17:44 server.***.com directadmin[1459]: 2022/02/08 13:17:44  info license updated successfully
Feb 08 13:47:52 server.***.com directadmin[1459]: 2022/02/08 13:47:52 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:48:28 server.***.com directadmin[1459]: 2022/02/08 13:48:28 error proxy request error       error=context canceled url=http://unix/
Feb 08 13:49:49 server.***.com directadmin[1459]: 2022/02/08 13:49:49  info license updated successfully
Feb 08 13:51:01 server.***.com systemd[1]: Stopping DirectAdmin Web Control Panel...
Feb 08 13:51:02 server.***.com systemd[1]: directadmin.service: Succeeded.
Feb 08 13:51:02 server.***.com systemd[1]: Stopped DirectAdmin Web Control Panel.
Feb 08 13:51:02 server.***.com systemd[1]: Starting DirectAdmin Web Control Panel...
Feb 08 13:51:02 server.***.com directadmin[30914]: 2022/02/08 13:51:02  info license updated successfully
Feb 08 13:51:02 server.***.com systemd[1]: Started DirectAdmin Web Control Panel.
Feb 08 13:53:14 server.***.com directadmin[30914]: 2022/02/08 13:53:14  info license updated successfully
Feb 08 13:57:03 server.***.com directadmin[30914]: 2022-02-08 13:57:03 cwd=/usr/local/directadmin 2 args: /usr/sbin/exim -bV
Feb 08 13:57:03 server.***.com systemd[1]: directadmin.service: Got notification message from PID 57288, but reception only permitted for main PID 30914
Feb 08 13:57:09 server.***.com directadmin[30914]: 2022-02-08 13:57:09 cwd=/usr/local/directadmin 2 args: /usr/sbin/exim -bV
Feb 08 13:57:09 server.***.com systemd[1]: directadmin.service: Got notification message from PID 58731, but reception only permitted for main PID 30914
Feb 08 13:57:29 server.***.com directadmin[30914]: 2022/02/08 13:57:29 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/ajax_count.raw?rand=0.5329857172565644
Feb 08 13:57:55 server.***.com directadmin[30914]: 2022/02/08 13:57:55  info license updated successfully
Feb 08 14:01:01 server.***.com systemd[1]: Stopping DirectAdmin Web Control Panel...
Feb 08 14:01:01 server.***.com systemd[1]: directadmin.service: Succeeded.
Feb 08 14:01:01 server.***.com systemd[1]: Stopped DirectAdmin Web Control Panel.
Feb 08 14:01:01 server.***.com systemd[1]: Starting DirectAdmin Web Control Panel...
Feb 08 14:01:02 server.***.com directadmin[68992]: 2022/02/08 14:01:02  info license updated successfully
Feb 08 14:01:02 server.***.com systemd[1]: Started DirectAdmin Web Control Panel.
Feb 08 14:03:01 server.***.com systemd[1]: Stopping DirectAdmin Web Control Panel...
Feb 08 14:03:01 server.***.com systemd[1]: directadmin.service: Succeeded.
Feb 08 14:03:01 server.***.com systemd[1]: Stopped DirectAdmin Web Control Panel.
Feb 08 14:03:01 server.***.com systemd[1]: Starting DirectAdmin Web Control Panel...
Feb 08 14:03:01 server.***.com directadmin[73572]: 2022/02/08 14:03:01  info license updated successfully
Feb 08 14:03:01 server.***.com systemd[1]: Started DirectAdmin Web Control Panel.
Feb 08 14:04:58 server.***.com directadmin[73572]: 2022/02/08 14:04:58  info license updated successfully
Feb 08 14:08:36 server.***.com directadmin[73572]: 2022/02/08 14:08:36  info license updated successfully
Feb 08 14:18:11 server.***.com directadmin[73572]: 2022/02/08 14:18:11 error proxy request error       error=context canceled url=http://unix/?redirect=yes
Feb 08 14:20:08 server.***.com directadmin[73572]: 2022/02/08 14:20:08  info license updated successfully
Feb 08 14:21:13 server.***.com systemd[1]: Stopping DirectAdmin Web Control Panel...
Feb 08 14:21:15 server.***.com systemd[1]: directadmin.service: Succeeded.
Feb 08 14:21:15 server.***.com systemd[1]: Stopped DirectAdmin Web Control Panel.
Feb 08 14:21:15 server.***.com systemd[1]: Starting DirectAdmin Web Control Panel...
Feb 08 14:21:15 server.***.com directadmin[103988]: 2022/02/08 14:21:15  info license updated successfully
Feb 08 14:21:15 server.***.com systemd[1]: Started DirectAdmin Web Control Panel.
Feb 08 14:21:58 server.***.com directadmin[103988]: 2022/02/08 14:21:58 error proxy request error       error=context canceled url=http://unix/
Feb 08 14:22:01 server.***.com directadmin[103988]: 2022/02/08 14:22:01 error proxy request error       error=context canceled url=http://unix/
Feb 08 14:23:21 server.***.com directadmin[103988]: 2022/02/08 14:23:21  info license updated successfully
Feb 08 14:27:10 server.***.com directadmin[103988]: 2022/02/08 14:27:10  info license updated successfully
Feb 08 14:38:49 server.***.com directadmin[103988]: 2022/02/08 14:38:49  info license updated successfully
I have managed VPS package, so I first ask for support of my hosting provider.
My journal after trying to load the page several times:
Feb 08 16:09:11 myserver.tld systemd[1]: Stopping DirectAdmin Web Control Panel...
Feb 08 16:09:13 myserver.tld systemd[1]: directadmin.service: Succeeded.
Feb 08 16:09:13 myserver.tld systemd[1]: Stopped DirectAdmin Web Control Panel.
Feb 08 16:09:13 myserver.tld systemd[1]: Starting DirectAdmin Web Control Panel...
Feb 08 16:09:13 myserver.tld directadmin[1902642]: 2022/02/08 16:09:13  info license updated successfully
Feb 08 16:09:13 myserver.tld systemd[1]: Started DirectAdmin Web Control Panel.
Feb 08 16:09:46 myserver.tld directadmin[1902642]: 2022/02/08 16:09:46 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:46 myserver.tld directadmin[1902642]: 2022/02/08 16:09:46 error proxy request error       error=context canceled url=http://unix/admin/license
Feb 08 16:09:48 myserver.tld directadmin[1902642]: 2022/02/08 16:09:48 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:49 myserver.tld directadmin[1902642]: 2022/02/08 16:09:49 error proxy request error       error=context canceled url=http://unix/admin/license
Feb 08 16:09:50 myserver.tld directadmin[1902642]: 2022/02/08 16:09:50 error proxy request error       error=context canceled url=http://unix/admin/license
Feb 08 16:09:50 myserver.tld directadmin[1902642]: 2022/02/08 16:09:50 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:51 myserver.tld directadmin[1902642]: 2022/02/08 16:09:51 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:52 myserver.tld directadmin[1902642]: 2022/02/08 16:09:52 error proxy request error       error=context canceled url=http://unix/admin/license
Feb 08 16:09:52 myserver.tld directadmin[1902642]: 2022/02/08 16:09:52 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:53 myserver.tld directadmin[1902642]: 2022/02/08 16:09:53 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:55 myserver.tld directadmin[1902642]: 2022/02/08 16:09:55 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:56 myserver.tld directadmin[1902642]: 2022/02/08 16:09:56 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:57 myserver.tld directadmin[1902642]: 2022/02/08 16:09:57 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:58 myserver.tld directadmin[1902642]: 2022/02/08 16:09:58 error proxy request error       error=context canceled url=http://unix/admin/license
Feb 08 16:09:58 myserver.tld directadmin[1902642]: 2022/02/08 16:09:58 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:09:59 myserver.tld directadmin[1902642]: 2022/02/08 16:09:59 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:10:06 myserver.tld directadmin[1902642]: 2022/02/08 16:10:06 error proxy request error       error=context canceled url=http://unix/?redirect=yes
Feb 08 16:10:11 myserver.tld directadmin[1902642]: 2022/02/08 16:10:11 error proxy request error       error=context canceled url=http://unix/?redirect=yes
Feb 08 16:11:10 myserver.tld directadmin[1902642]: 2022/02/08 16:11:10  info license updated successfully
Feb 08 16:11:21 myserver.tld directadmin[1902642]: 2022/02/08 16:11:21 error proxy request error       error=context canceled url=http://unix/user/messages
Feb 08 16:11:34 myserver.tld directadmin[1902642]: 2022/02/08 16:11:34 error proxy request error       error=context canceled url=http://unix/user/messages
Feb 08 16:12:19 myserver.tld directadmin[1902642]: 2022/02/08 16:12:19 error proxy request error       error=context canceled url=http://unix/user/messages
Feb 08 16:13:13 myserver.tld directadmin[1902642]: 2022/02/08 16:13:13 error proxy request error       error=context canceled url=http://unix/reseller/tickets
Feb 08 16:14:56 myserver.tld directadmin[1902642]: 2022/02/08 16:14:56  info license updated successfully
Feb 08 16:16:44 myserver.tld directadmin[1902642]: 2022/02/08 16:16:44 error proxy request error       error=context canceled url=http://unix/reseller/tickets
Feb 08 16:21:29 myserver.tld directadmin[1902642]: 2022/02/08 16:21:29 error proxy request error       error=context canceled url=http://unix/reseller/users/avantiback/view/domains
Feb 08 16:23:58 myserver.tld directadmin[1902642]: 2022/02/08 16:23:58 error proxy request error       error=context canceled url=http://unix/admin/license?redirect=yes
Feb 08 16:24:01 myserver.tld directadmin[1902642]: 2022/02/08 16:24:01 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:24:03 myserver.tld directadmin[1902642]: 2022/02/08 16:24:03 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:24:04 myserver.tld directadmin[1902642]: 2022/02/08 16:24:04 error proxy request error       error=context canceled url=http://unix/admin/license?redirect=yes
Feb 08 16:24:05 myserver.tld directadmin[1902642]: 2022/02/08 16:24:05 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:24:07 myserver.tld directadmin[1902642]: 2022/02/08 16:24:07 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:24:08 myserver.tld directadmin[1902642]: 2022/02/08 16:24:08 error proxy request error       error=context canceled url=http://unix/admin/license?redirect=yes
Feb 08 16:24:10 myserver.tld directadmin[1902642]: 2022/02/08 16:24:10 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:24:11 myserver.tld directadmin[1902642]: 2022/02/08 16:24:11 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:25:41 myserver.tld directadmin[1902642]: 2022/02/08 16:25:41  info license updated successfully
Feb 08 16:25:46 myserver.tld directadmin[1902642]: 2022/02/08 16:25:46 error proxy request error       error=context canceled url=http://unix/admin/license?redirect=yes
Feb 08 16:25:49 myserver.tld directadmin[1902642]: 2022/02/08 16:25:49 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:25:50 myserver.tld directadmin[1902642]: 2022/02/08 16:25:50 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:25:51 myserver.tld directadmin[1902642]: 2022/02/08 16:25:51 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:25:52 myserver.tld directadmin[1902642]: 2022/02/08 16:25:52 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Feb 08 16:25:53 myserver.tld directadmin[1902642]: 2022/02/08 16:25:53 error proxy request error       error=context canceled url=http://unix/CMD_PLUGINS_ADMIN/custombuild/updates_count.raw?json=yes&url=%2FCMD_PLUGINS_ADMIN%2Fcustombuild%2Fupdates_count.raw
Did anyone noticed that when restarting the Exim Service from GUI it takes much time now to restart.
previously it used to restart within 10 seconds.
Devtools is showing a status 401 for the xhr calls to /api/license and /api/version
Also the rspamd page and the netdata page are suddenly showing an "Unauthorized" message (status 401)
Update: Using the enhanced skin the license page just shows "Unauthorized".
May you create a ticket with access details?
I have an Centos 6 ELS box which is now stucked at 1.63.5 , will this security fix applied somehow to 1.63.5 ?
Why is this security fix not available to 1.63.5 ?
I have no issues accessing the License page
I am on Debian 11
v1.63.6 has -
Updated ClamAV feature user interface evolution improved
ClamAV feature now allows to select a pre-defined scan paths to avoid having to type in scan path manually. It is still possible to use custom scan path.
clamav is installed and running fine.,
But I dont see ClamAV icon or any link in GUI, is there any additional step to be taken to make it visible in GUI
...and no, the ClamAV manager is not shown, and the option to activate it in user packages is not shown either.
Try a reset
its on the user side next to Git
