DirectAdmin does not automatically SSL my domain
Johnws2022
Dear Sir,
I have my server being attacked, and I reinstalled it.
After fresh installation of DirectAdmin on Centos 7, both main domains and other domain are not automatically set with SSL.
Can you please how can I fix this issue?
I appreciate your help.
Cheers
JW
Login to this Direct Admin account
Go to SSL certificate
Click first option, Free & automatic certificate from Let's Encrypt
Generate new SSL certificate
That's all.
This will generate new SSL certificate for this account.
That's all.
Thank you for prompt support. But it does not work.
I found out that I added a main domain after adding another domain into DirectAdmin.
I reinstall my server, and added the main domain first, and other domains after. Auto SSL is working now.
Many thanks
JW
