Roundcube error CAPABILITY
siwy113
Hello
I have a problem after the update, the mail on the server does not work.
if you are able to help me, I will be very grateful
Błąd serwera: CAPABILITY: Internal error occurred. Refer to server log for more information. after logging in to Roundcube
LOG
Error: Couldn't load required plugin /usr/lib/dovecot/lib21_fts_xapian_plugin.so: dlopen() failed: libicuio.so.66: cannot open shared object file: No such file or directory
Reply
Hello
There is such a message after updating DA
I fixed this on CentOS Stream 8 by adding the following path which contain the missing libraries to /etc/ld.so.conf.d/icu.conf:
/usr/local/icu/lib/
Make sure to run ldconfig before restarting dovecot.
