HTscanner not working in php 8.1? Build error.
Richard G
Maastricht
I'm trying to install php 8.1 but on building htscanner I get a build error.
I used the global command from the docs, but same happens when I used the specific command:
./build php_htscanner2 81
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:44:1: warning: parameter names (without types) in function declaration [enabled by default]
 int (*php_cgi_sapi_activate)(TSRMLS_D);
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:89:90: error: expected ';', ',' or ')' before 'TSRMLS_DC'
 static int value_hnd(char *name, char *value, int flag, int mode, HashTable *ini_entries TSRMLS_DC)
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:184:66: error: expected ';', ',' or ')' before 'TSRMLS_DC'
 static void parse_config_file(char *file, HashTable *ini_entries TSRMLS_DC)
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c: In function 'htscanner_main':
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:334:134: error: expected ')' before 'TSRMLS_CC'
  if (HTG(force_default_docroot) || !sapi_module.getenv || !(doc_root = sapi_module.getenv("DOCUMENT_ROOT", sizeof("DOCUMENT_ROOT")-1 TSRMLS_CC))) {
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:363:28: error: 'TSRMLS_C' undeclared (first use in this function)
  t = sapi_get_request_time(TSRMLS_C);
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:363:28: note: each undeclared identifier is reported only once for each function it appears in
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:363:2: error: too many arguments to function 'sapi_get_request_time'
In file included from /usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:29:0:
/usr/local/php81/include/php/main/SAPI.h:209:17: note: declared here
 SAPI_API double sapi_get_request_time(void);
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:424:41: error: expected ')' before 'TSRMLS_CC'
     parse_config_file(file, ini_entries TSRMLS_CC);
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c: In function 'sapi_cgi_activate':
/usr/local/directadmin/custombuild/htscanner-1.0.1-enhanced/htscanner.c:450:25: error: 'TSRMLS_C' undeclared (first use in this function)
   php_cgi_sapi_activate(TSRMLS_C);
make: *** [htscanner.lo] Error 1
Does 8.1 not support htscanner? If it does support it, can this be fixed please @smtalk
what happens if you just run
./build mod_htscanner2
That only builds the module for apache, not for php.
I'm talking about the command I gave to build it for php. I know you don't use that, but I do.
And you might want to remove it from the build script too...
./build php_htscanner2 php_release
It works for old PHP versions, some people may still use it. mod_ruid2, for example, is also supported, but doesn't work on newest OS :)
