Richard G
Suppose my first php version is php 7.4. Now I want to change that to for example a 3rd php option and put php 8.0 first for example.
How do we change this for all default users?
As php1_select=1 is not present for default users in their domain.tld.conf file we can't use any command which says "move everybody who has php_select=1 to php_select=3 (for example).
See my post about same thing for listing php versions here:
forum.directadmin.com
Shouldn't a php1_select= setting always be present in the domains.tld.conf file for easy listing as well as moving purposes?
List all PHP-versions for all domains
Mine is now showing php versions in both enhanced and evolution and I didn't install a plugin. I don't think I did anything to change it. It just started showing.
