Where are SSH Directadmin magento site path
Angelo
Hi everyone,
I install magento site by from Softaculous.
But I don't know, where are SSH Directadmin magento site path?
I want to use magento command. for example:
php bin/magento cache:clean
php bin/magento indexer:reindex
Thanks,
You need to raise the 'memory_limit' setting in your php.ini file, i.e. from 128M to 512M, and restart your webserver/php-fpm afterwards. The error seems to show you currently have a value of 128M.
I've tried changing some parameters, but it still doesn't work.
Do you still get the error when you run the magento cache commands? If you do, try to create a phpinfo(); file in your public_html folder. What is the memory_limit value in the phpinfo(); file?
{"0":"Class Magento\\Catalog\\Model\\Indexer\\Product\\Price\\PriceTableResolver\\Proxy does not exist","1":"#1 Magento\\Framework\\Code\\Reader\\ClassReader->getConstructor() called at [vendor\/magento\/framework\/ObjectManager\/Definition\/Runtime.php:54]\n#2 Magento\\Framework\\ObjectManager\\Definition\\Runtime->getParameters() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:48]\n#3 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:70]\n#4 Magento\\Framework\\ObjectManager\\ObjectManager->get() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:170]\n#5 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:276]\n#6 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->getResolvedArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:239]\n#7 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgumentsInRuntime() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:34]\n#8 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->_resolveArguments() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:59]\n#9 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:70]\n#10 Magento\\Framework\\ObjectManager\\ObjectManager->get() called at [vendor\/magento\/framework\/Interception\/PluginList\/PluginList.php:174]\n#11 Magento\\Framework\\Interception\\PluginList\\PluginList->getPlugin() called at [vendor\/magento\/framework\/Interception\/Interceptor.php:144]\n#12 Magento\\Framework\\App\\ResourceConnection\\Interceptor->Magento\\Framework\\Interception\\{closure}() called at [vendor\/magento\/framework\/Interception\/Interceptor.php:153]\n#13 Magento\\Framework\\App\\ResourceConnection\\Interceptor->___callPlugins() called at [generated\/code\/Magento\/Framework\/App\/ResourceConnection\/Interceptor.php:50]\n#14 Magento\\Framework\\App\\ResourceConnection\\Interceptor->getTableName() called at [vendor\/magento\/framework\/Session\/SaveHandler\/DbTable.php:50]\n#15 Magento\\Framework\\Session\\SaveHandler\\DbTable->__construct() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:121]\n#16 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->createObject() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:66]\n#17 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:56]\n#18 Magento\\Framework\\ObjectManager\\ObjectManager->create() called at [vendor\/magento\/framework\/Session\/SaveHandlerFactory.php:61]\n#19 Magento\\Framework\\Session\\SaveHandlerFactory->create() called at [vendor\/magento\/framework\/Session\/SaveHandler.php:171]\n#20 Magento\\Framework\\Session\\SaveHandler->callSafely() called at [vendor\/magento\/framework\/Session\/SaveHandler.php:81]\n#21 Magento\\Framework\\Session\\SaveHandler->open()\n#22 session_start() called at [vendor\/magento\/framework\/Session\/SessionManager.php:204]\n#23 Magento\\Framework\\Session\\SessionManager->start() called at [vendor\/magento\/framework\/Interception\/Interceptor.php:58]\n#24 Magento\\Framework\\Session\\Generic\\Interceptor->___callParent() called at [vendor\/magento\/framework\/Interception\/Interceptor.php:138]\n#25 Magento\\Framework\\Session\\Generic\\Interceptor->Magento\\Framework\\Interception\\{closure}() called at [vendor\/magento\/framework\/Interception\/Interceptor.php:153]\n#26 Magento\\Framework\\Session\\Generic\\Interceptor->___callPlugins() called at [generated\/code\/Magento\/Framework\/Session\/Generic\/Interceptor.php:41]\n#27 Magento\\Framework\\Session\\Generic\\Interceptor->start() called at [vendor\/magento\/framework\/Session\/SessionManager.php:141]\n#28 Magento\\Framework\\Session\\SessionManager->__construct() called at [generated\/code\/Magento\/Framework\/Session\/Generic\/Interceptor.php:14]\n#29 Magento\\Framework\\Session\\Generic\\Interceptor->__construct() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:121]\n#30 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->createObject() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:66]\n#31 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:70]\n#32 Magento\\Framework\\ObjectManager\\ObjectManager->get() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:170]\n#33 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:276]\n#34 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->getResolvedArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:239]\n#35 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgumentsInRuntime() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:34]\n#36 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->_resolveArguments() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:59]\n#37 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:70]\n#38 Magento\\Framework\\ObjectManager\\ObjectManager->get() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:170]\n#39 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:276]\n#40 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->getResolvedArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:239]\n#41 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgumentsInRuntime() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:34]\n#42 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->_resolveArguments() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:59]\n#43 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:70]\n#44 Magento\\Framework\\ObjectManager\\ObjectManager->get() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:170]\n#45 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:276]\n#46 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->getResolvedArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:239]\n#47 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgumentsInRuntime() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:34]\n#48 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->_resolveArguments() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:59]\n#49 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:70]\n#50 Magento\\Framework\\ObjectManager\\ObjectManager->get() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:206]\n#51 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->parseArray() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:182]\n#52 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:276]\n#53 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->getResolvedArgument() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:239]\n#54 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->resolveArgumentsInRuntime() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:34]\n#55 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->_resolveArguments() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:59]\n#56 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:70]\n#57 Magento\\Framework\\ObjectManager\\ObjectManager->get() called at [vendor\/magento\/framework\/App\/FrontController.php:109]\n#58 Magento\\Framework\\App\\FrontController->__construct() called at [generated\/code\/Magento\/Framework\/App\/FrontController\/Interceptor.php:14]\n#59 Magento\\Framework\\App\\FrontController\\Interceptor->__construct() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/AbstractFactory.php:121]\n#60 Magento\\Framework\\ObjectManager\\Factory\\AbstractFactory->createObject() called at [vendor\/magento\/framework\/ObjectManager\/Factory\/Dynamic\/Developer.php:66]\n#61 Magento\\Framework\\ObjectManager\\Factory\\Dynamic\\Developer->create() called at [vendor\/magento\/framework\/ObjectManager\/ObjectManager.php:70]\n#62 Magento\\Framework\\ObjectManager\\ObjectManager->get() called at [vendor\/magento\/framework\/App\/Http.php:115]\n#63 Magento\\Framework\\App\\Http->launch() called at [generated\/code\/Magento\/Framework\/App\/Http\/Interceptor.php:23]\n#64 Magento\\Framework\\App\\Http\\Interceptor->launch() called at [vendor\/magento\/framework\/App\/Bootstrap.php:264]\n#65 Magento\\Framework\\App\\Bootstrap->run() called at [pub\/index.php:29]\n","url":"\/","script_name":"\/pub\/index.php","report_id":"01c1f2b2780e2b0d3cbd698d3ab89cc08e0384e1f3dcae0bd321fb30bb5eed4a"}
Hi wtptrs
How to modify it please. I can't seem to find the modified entry.
PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 20480 bytes) in /home/admin/domains/123456.com/public_html/vendor/magento/module-config/Model/Config/Structure/Mapper/ExtendsMapper.php on line 166
Check https://getcomposer.org/doc/articles/troubleshooting.md#memory-limit-errors for more info on how to handle out of memory errors.root@www:/home/admin/domains/123456.com/public_html# php -r "echo ini_get('memory_limit').PHP_EOL;"
128M
You have to look at your servers php.ini file.
Normally it can be found in /usr/local/phpXX/lib directory. Where phpXX stands for the php version, for example php 7.3 would be /php73/ in this example.
Thanks, i found php and modified it.
root@www:/home/admin/domains/123456.com/public_html# /usr/local/bin/php --ini | grep 'Loaded Configuration File'
Loaded Configuration File: /usr/local/php74/lib/php.ini
root@www:/home/admin/domains/123456.com/public_html# cd
root@www:~# cd /usr/local/php74/lib/
root@www:/usr/local/php74/lib# ls
libphp7.so php php.conf.d php.ini
root@www:/usr/local/php74/lib# vi php.ini
