Solved [PHP Config] Enable OR Disable open_basedir, subdomains disappear
Ohm J
When I disable then re-enable open_basedir, all subdomain inside that domain will disappear, (it not completely disappear)
So When I re-add subdomain. it come back again ( With any custom setting )
###UPDATE
solve it on 1.63.9
We encounter the same problem. Is this a bug in DirectAdmin? We use the latest DirectAdmin version.
yes it bug ;( , but DA focus on report Ticket , im too lazy to create ticket.
Any news on that bug? Cause it seems to still be in the latest DA version!
@andy77
Could you try create ticket to give DA team check it directly on your server ?
My Server is in production, I can't do that anymore.
So why I just create threads in here.
Email doesn't usually work you need to create a ticket.
