This Site can't reach an s some time Database Connection Error
Ali khan
This site can’t be reachedghafarimarketing.com took too long to respond.
Try:
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_TIMED_OUT
Can’t select database​
We were able to connect to the database server (which means your username and password is okay) but not able to select the ghafari1_ghafarinew database.
  • Are you sure it exists?
  • Does the user ghafari1_ghafarinew have permission to use the ghafari1_ghafarinew database?
  • On some systems the name of your database is prefixed with your username, so it would be like username_ghafari1_ghafarinew. Could that be the problem?
If you don’t know how to set up a database you should contact your host. If all else fails you may find help at the WordPress Support Forums.
also get error while accessing MySQL management in cPanel as screenshot is attached below
Something is wrong with your domain registration or dns
DNS Report for reachedghafarimarketing.com
Oops! I can't find that domain at all! Perhaps it doesn't exist or registration is not current? Sorry!
DNS propagation results for reachedghafarimarketing.com
Sorry, there don't seem to be any A records configured for this domain/hostname. Perhaps you entered an invalid domain name? Please check the spelling and try again later.
No it's not... read the line, he forgot a space between read and his domain name. The name is ghafarimarketing.com and that looks good except for the PTR record.
@Ali khan it seems your mysql server isn't running. Check if it's running or try restarting it and look why it fails.
I'm here in the USA and the site wont load at all. Oh wait, it loaded after about a minute. Never saw that before... and that domain is hosted at a location less than an hour drive from me. Probably not a good idea to be posting the name of the database publicly.
