Third-party software database connection
fabioweb90
Hello, a client asked me to allow a software connecting with a database. In short there is a software hosted somewhere that need access to my database
Here the message that third-party software wrote to my client
Unfortunately, your hosting provider doesn't allow connections to the database with third-party software I'm afraid.
Please, contact your hosting provider to ask if it is possible to allow connections only for a certain IP or something similar.
Is it possible to allow external database connection with Directadmin for a database only?
Thanks for helping
But do note that the firewall by default blocks port 3306 and thus you also need to allow 3306 to not be blocked in the firewall.
Thanks i can check with following command
lsof -i
if port is open or not
then with
firewall-cmd --zone=public --add-port=3306/tcp --permanent
i can open that port right?
Yeah i can understand. I read about restric remote access to a specific IP in this way
sudo firewall-cmd --new-zone=mysqlzone --permanent
sudo firewall-cmd --reload
sudo firewall-cmd --permanent --zone=mysqlzone --add-source=10.8.0.5/32
sudo firewall-cmd --permanent --zone=mysqlzone --add-port=3306/tcp
What do you think?
