Block TOR IPs using CSF csf.blocklists
itcms
Athens
If you have observe there are lists under csf.blocklists which not working
cat /etc/csf/csf.blocklists
Example TOR Exit Nodes List
If you want to block extra TOR ip , avoiding attacks then edit /etc/csf/csf.blocklists and add
TOR3|86400|0|https://raw.githubusercontent.com/SecOps-Institute/Tor-IP-Addresses/master/tor-nodes.lst
Finally text :
# TOR Exit Nodes List
# Set URLGET in csf.conf to use LWP as this list uses an SSL connection
# Details: https://trac.torproject.org/projects/tor/wiki/doc/TorDNSExitList
#TOR|86400|0|https://check.torproject.org/cgi-bin/TorBulkExitList.py?ip=1.2.3.4 <-- THIS IS THE DEFAULT NOT WORKING
Save and restart csf
csf -r
