Skin
thiagodifoiz
I'm new to directadmin, I went to test an old skin named: evolution
and unfortunately I can't get back to the skin: enhanced
Does anyone have an idea how to get back? I did this in the panel but no effect appears.
Evolution is in fact the new skin.
You shouldn't make the change there.
Go to the reseller section -> Skin Manager, select enhanced skin and then apply to me or everybody or whatever.
If you can't find it in Evolution skin, just type "skin" in the search bar, you will see the "skin manager". Click on that, and then it's basically the same to get back to enhanced skin.
The change does not apply.
I believe it is incompatibility with Almalinux 8
No it has nothing to do with that. Works fine on Almalinux.
You're still making screenshots of the admin section. Make screenshot of the skin manager in the reseller section where I told.
That's where you need to change, not where the screenshots are.
By the way, the screenshots are from Enhanced skin. So do you want to change to Evolution? Because you said you wanted to change back to Enhanced.
