One server behind files.directadmin.com is outdated
kristian
Norway
I noticed that some of my hosts reported available updates, that were in fact downgrades. Turns out that the server at 69.162.69.58 behind files.directadmin.com serves an outdated versions.txt file, and possibly other things:
$ dig files.directadmin.com +short
69.162.69.58
104.128.54.74
185.42.221.168
$ curl -sk -H "Host: files.directadmin.com" https://69.162.69.58/services/custombuild/versions.txt | grep ^php80
php80:8.0.17:3b31e7657bcc1686d960884197dd4cca
$ curl -sk -H "Host: files.directadmin.com" https://104.128.54.74/services/custombuild/versions.txt | grep ^php80
php80:8.0.18:d43587670b3bda91011f38e8d3b65bbb
$ curl -sk -H "Host: files.directadmin.com" https://185.42.221.168/services/custombuild/versions.txt | grep ^php80
files.directadmin.com is not listed (anymore?) as an official mirror:
Also:
It's not listed as a mirror, because it's the main source, at least that's my impression.
files1 and files2 are actually part of files, in terms of DNS:
104.128.54.74
185.42.221.168
69.162.69.58
$ dig files1.directadmin.com +short
104.128.54.74
$ dig -x 104.128.54.74 +short
files1.directadmin.com.
$ dig files2.directadmin.com +short
185.42.221.168
$ dig -x 185.42.221.168 +short
files2.directadmin.com.
The last one doesn't seem to be a filesXX host, but rather the forum:
$ dig -x 69.162.69.58 +short
forum.directadmin.com.
I don't know the history behind this setup, but by using files.directadmin.com, you're hitting either files1 or files2 roughly 66% of the time. :) I suppose switching to either one of them is fine, but it's also nice to have multiple IP addresses for some simple redundancy without having to change the downloadserver used.
just run
./build set_fastest
