Solved Cant install php 80 and 81
hmaddy
Making PHP 8.1 installation compatible with php.ini file
Installing php...
Installing PHP SAPI module: embed
Installing shared extensions: /usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/
Installing PHP CLI binary: /usr/local/php81/bin/
Installing PHP CLI man page: /usr/local/php81/php/man/man1/
Installing PHP FPM binary: /usr/local/php81/sbin/
Installing PHP FPM defconfig: skipping
Installing PHP FPM man page: /usr/local/php81/php/man/man8/
Installing PHP FPM status page: /usr/local/php81/php/php/fpm/
Installing PHP LiteSpeed binary: /usr/local/php81/bin/
Installing phpdbg binary: /usr/local/php81/bin/
Installing phpdbg man page: /usr/local/php81/php/man/man1/
Installing PHP CGI binary: /usr/local/php81/bin/
Installing PHP CGI man page: /usr/local/php81/php/man/man1/
Installing build environment: /usr/local/php81/lib/php/build/
Installing header files: /usr/local/php81/include/php/
Installing helper programs: /usr/local/php81/bin/
program: phpize81
program: php-config81
Installing man pages: /usr/local/php81/php/man/man1/
page: phpize81.1
page: php-config81.1
Installing PEAR environment: /usr/local/php81/lib/php/
PHP Warning: PHP Startup: Unable to load dynamic library 'clos_ssa.so' (tried: /usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/clos_ssa.so (/usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/clos_ssa.so: cannot open shared object file: No such file or directory), /usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/clos_ssa.so.so (/usr/local/php81/lib/php/extensions/no-debug-non-zts-20210902/clos_ssa.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
make[1]: *** [install-pear-installer] Segmentation fault
make: *** [install-pear] Error 2
ps aux | grep php
root 1835110 0.2 0.0 1621380 15104 ? Ssl Feb23 198:30 /usr/sbin/imunify360-php-daemon
root 3820007 0.1 0.0 451584 27192 ? Ss 15:06 0:03 php-fpm: master process (/usr/local/php56/etc/php-fpm.conf)
root 3820025 0.0 0.0 458720 16928 ? Ss 15:06 0:00 php-fpm: master process (/usr/local/php73/etc/php-fpm.conf)
root 3835057 0.0 0.0 454456 17012 ? Ss 15:07 0:00 php-fpm: master process (/usr/local/php74/etc/php-fpm.conf)
uapanel 4024176 0.2 0.2 569272 67364 ? S 15:28 0:01 php-fpm: pool uapanel
alexisw+ 4024335 0.0 0.0 517208 14132 ? S 15:28 0:00 php-fpm: pool alexisworld
uapanel 4024340 0.0 0.0 517212 12772 ? S 15:28 0:00 php-fpm: pool uapanel
uapanel 4025022 0.3 0.2 570488 67904 ? S 15:28 0:01 php-fpm: pool uapanel
uapanel 4025726 0.0 0.0 517212 12756 ? S 15:28 0:00 php-fpm: pool uapanel
alexisw+ 4025980 0.0 0.0 518492 14384 ? S 15:28 0:00 php-fpm: pool alexisworld
alexisw+ 4029528 0.0 0.0 517216 13016 ? S 15:31 0:00 php-fpm: pool alexisworld
uapanel 4030523 0.0 0.0 517212 12736 ? S 15:32 0:00 php-fpm: pool uapanel
root 4032390 1.7 0.4 373272 147148 ? Ss 15:34 0:00 /opt/alt/php-internal/usr/bin/php -n -d short_open_tag=on -d extension=zip.so -d extension=leveldb.so -d extension=posix.so -d extension=json.so -d extension=mbstring.so -d extension=hyperscan.so /opt/ai-bolit/ai-bolit-hoster.php --resident --smart --use-heuristics-ignore --deobfuscate --memory=2G --no-html --avdb=/var/imunify360/files/sigs/v1/aibolit/ai-bolit-hoster-full.db --hs=/var/imunify360/files/sigs/v1/aibolit/hyperscan --skip-system-owner --skip-imunify360-storage --encode-b64-fn --scan-archive
juliet 4032655 3.5 0.3 600100 98808 ? S 15:34 0:01 php-fpm: pool juliet
webapps 4032661 0.1 0.0 455588 19668 ? S 15:34 0:00 php-fpm: pool webapps
websouse 4033316 0.0 0.0 518524 12904 ? S 15:35 0:00 php-fpm: pool websouse
aasthad+ 4033322 16.2 0.1 466472 54780 ? S 15:35 0:03 php-fpm: pool aasthadefence
geturlkg 4033417 2.1 0.1 455520 60356 ? S 15:35 0:00 php-fpm: pool geturlkg
juliet 4033435 9.0 0.3 532856 97412 ? S 15:35 0:01 php-fpm: pool juliet
ybpatil 4033596 21.0 0.2 552512 63628 ? S 15:35 0:01 php-fpm: pool ybpatil
pushmyw+ 4033610 28.8 0.2 507260 77196 ? R 15:35 0:01 php-fpm: pool pushmyweb
ybpatil 4033613 45.6 0.4 551276 128376 ? R 15:35 0:02 php-fpm: pool ybpatil
root 4033739 0.0 0.0 110804 904 pts/1 S+ 15:35 0:00 grep --color=auto php
This module is not available for php 8.0 and 8.1 as far as I now.
So you might have to wait until this module is released for php 8.x or use another solution like Cloudlinux (seems available there).
With php 8.0? It's the PHP-SSA, so the Slow Site Analyzer which is causing the issue.
That's a seperate plugin, how did you install that?
Are you on Cloudinux or not?
Try via SSH as root:
yum install alt-php-ssa
it should install from the cloudlinux repo.
After that, try to compile php8 again.
If it still not works, you have to contact Cloudlinux, because this is a Cloudlinux issue.
