Dovecot 2.3.18 & 2.3.19
Dauser2007
After update the Dovecot to 2.3.19 , email server will completed down
Go back to 2.3.18 working fine !
I have updated to 2.3.19, and the servers are working fine. You should find the reason in the error log.
I will keep on the 2.3.18 for the moment , very strange , this is first time ! thanks for reply
You're probably going to want to take a look at the error log. Mine also updated without issues, and there don't appear to be any widespread reports of issues with this release.
Same here, updated Centos 7.9 servers and a Almalinux 8.5 server, no issues at all.
You might want to try updating with another mirror.
Thanks u guys confirm the situation , today , i have manually updated V2.3.19 , working fine now !
But if try to update by CustomBuild 2.0 plugs, still get same problem !
anyway the problem fixed !
thanks again
I have to admit, lately on some servers files downloaded by Custombuild have MD5 error,
After cleanup and redownload the files the problems disappear but its strange, that explains also some installation error we had with installing ClamAV lately
I thought when MD5 checking is failed, CB2 should re-download automatically, but is it not working like that in your case?
True, but second attempt do not display any errors , but at that point no any updates are shown.
Its an odd situation, but happened few times so maybe its worth to mention here
