can't update mysql
mikajaxxx
Hello
in directadmin/ Custom Build always update message for mysql 5.7.36 to 5.7.37 has been shown, the process starts but after fininshing i get the upgrade message again. i have no idea what is the problem. the following codes extracted from upgrade log. i also tried upgrading by SSH but the same result
 Stopping mysqld ...
Service didn't get stopped, sleeping for 20 secs and re-trying ...
Stopping mysqld ...
Updating MySQL 5.7.36 to 5.7.37
warning: mysql-community-client-5.7.37-1.el7.x86_64.rpm: Header V4 RSA/SHA256 Signature, key ID 3a79bd29: NOKEY
Preparing... ########################################
Updating / installing...
mysql-community-common-5.7.37-1.el7 ########################################
mysql-community-libs-5.7.37-1.el7 ########################################
mysql-community-client-5.7.37-1.el7 ########################################
error: unpacking of archive failed on file /usr/bin/mysql;627e0702: cpio: read failed - Inappropriate ioctl for device
error: mysql-community-client-5.7.37-1.el7.x86_64: install failed
mysql-community-server-5.7.37-1.el7 ########################################
mysql-community-devel-5.7.37-1.el7 ########################################
mysql-community-libs-compat-5.7.37-1.e########################################
error: mysql-community-client-5.7.36-1.el7.x86_64: erase skipped
Ensuring local-infile is disabled for security reasons in MySQL configuration file...
Giving mysqld a few seconds to start up...
Checking if update is needed.
This installation of MySQL is already upgraded to 5.7.37, use --force if you still need to run mysql_upgrade
check mysql error log, there must be more details, also:
try remove downloaded archives from /custombuild directory, update fileserver mirror
./build set_fastest
and run update again
it didin't work bro still get update message in directaadmin panel
 Found /usr/local/directadmin/custombuild/mysql/mysql-community-client-5.7.37-1.el7.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/mysql-community-devel-5.7.37-1.el7.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/mysql-community-server-5.7.37-1.el7.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/mysql-community-libs-5.7.37-1.el7.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/mysql-community-libs-compat-5.7.37-1.el7.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/mysql-community-common-5.7.37-1.el7.x86_64.rpm
Stopping mysqld ...
Stopping mysqld ...
error: unpacking of archive failed on file /usr/bin/mysql;628427b1: cpio: read failed - Inappropriate ioctl for device
What is the output of mysql -V because it seems you can't upgrade something you're already running.
Anyway, check what mirror you are currently using. Then use the set_fastest command again and see if it changed. If not, change the mirror manually restart directadmin and try again.
strange, all ok with your disk? enough space? no errors in dmesg?
 mysql -V
mysql  Ver 14.14 Distrib 5.7.36, for Linux (x86_64) using  EditLine wrapper
Also in directadmin i have update message!
I have absolutly no problem on updating other extensions or directadmin the only extension doesn't updated is mysql
You can just have a look in the /usr/local/directadmin/custombuild/options.conf file for a line like:
downloadserver=
check what it says not, then do:
./build set_fastest
from the custombuild directory
and see if that line has another server there.
If not, change manually to:
downloadserver=files1.directadmin.com
or
downloadserver=files-fi.directadmin.com
which are 2 working examples.
Then do ./build update
again and then try to update mysql again with ./build update_versions command.
Hello
ok here is the codes before changing mirror
###################################################################################################################################################################################################################################### 100.0%
Extracting custombuild.tar.gz...
Cronjob frequency: daily
Automatic notifications: no
Automatic updates: no
Installing sa-update cronjob...
Downloading             sa-update.sh...
Automatic SpamAssassin rule updates: daily
 ./build set_fastest
Testing with file 10.kb:
2023 B/s        - files-fi.directadmin.com
8477 B/s        - files-fr.directadmin.com
2010 B/s        - files-lt.directadmin.com
3938 B/s        - files-de.directadmin.com
327 B/s         - files-sg.directadmin.com
1012 B/s        - files-ca.directadmin.com
Total test duration: 1 seconds
Testing with file 100.kb:
2403 B/s        - files-fi.directadmin.com
23485 B/s       - files-fr.directadmin.com
2363 B/s        - files-lt.directadmin.com
5453 B/s        - files-de.directadmin.com
1154 B/s        - files-ca.directadmin.com
Fastest server is files-fr.directadmin.com at 23485 B/s
Changed downloadserver option from files2.directadmin.com to files-fr.directadmin.com
i run the update and nothing changed!
next i changed the mirror and
Stopping mysqld ...
Stopping mysqld ...
Preparing...                          ################################# [100%]
   1:mysql-community-common-5.7.37-1.e################################# [ 14%]
   2:mysql-community-libs-5.7.37-1.el7################################# [ 29%]
   3:mysql-community-client-5.7.37-1.e################################# [ 43%]
error: unpacking of archive failed on file /usr/bin/mysql;628a3be6: cpio: read
It didn't work bro
It didn't work bro
Ah wait....
Custombuild found them, they were not downloaded again.
Remove those rpm files, then try the update_versions again please?
It should download the RPM's again. If it does and still throws the error, then I guess a support ticket is needed or somebody else must know what to do.
