[AntiDDoS] for DirectAdmin with vDDoS Proxy Protection
duy13
STEP 1: Install DirectAdmin
bash <(curl -LSs https://download.directadmin.com/setup.sh || curl -LSs https://download-alt.directadmin.com/setup.sh) 'Provided license key should go here'
More documentation:
STEP 2: Install vDDoS Proxy Protection
vDDoS Proxy Protection is free software to provide a Reverse Proxy Server HTTP(S) protocols. It act as a Layer 7 Firewall Filter & Mitigate DOS, DDOS, SYN Floods, or HTTP Floods attack to protect your website.
wget https://files.voduy.com/vDDoS-Proxy-Protection/latest.sh ; chmod 700 latest.sh ; bash latest.sh
More documentation:
https://vddos.voduy.com
STEP 3: Change Apache Default Port
echo 'port_80=8080' >> /usr/local/directadmin/data/templates/directadmin.conf
echo 'port_443=8443' >> /usr/local/directadmin/data/templates/directadmin.conf
echo 'port_80=8080' >> /usr/local/directadmin/conf/directadmin.conf
echo 'port_443=8443' >> /usr/local/directadmin/conf/directadmin.conf
To issue a rewrite of the configs, type:
./build rewrite_confs
More documentation:
https://www.directadmin.com/features.php?id=1238
Re-Check Apache port:
[root@vDDoS-DirectAdmin ~]# netstat -lntup|grep httpd
tcp6       0      0 :::8080                 :::*                    LISTEN      2404/httpd
tcp6       0      0 :::8443                 :::*                    LISTEN      2404/httpd
STEP 4: Config vDDoS Proxy Protection
For example, the IP Addr of your server is 1.2.3.4:
nano /vddos/conf.d/website.conf
# Website       Listen               Backend                  Cache Security SSL-Prikey   SSL-CRTkey
default         http://0.0.0.0:80    http://1.2.3.4:8080    no    no      no           no
default         https://0.0.0.0:443  https://1.2.3.4:8443   no    no      /vddos/ssl/your-domain.com.pri /vddos/ssl/your-domain.com.crt
Restart vDDoS service after you have configured:
/usr/bin/vddos restart
STEP 5: Config vDDoS Auto Add
vDDoS Auto Add is a addon support for vDDoS Proxy Protection - Monitor Domains/Aliasdomains/Subdomains in Panel Hosting, Web Server, List Domain, Virtual Host... and automatically add them into the website.conf file.
nano /vddos/auto-add/setting.conf
# Default Setting for vddos-add command:
SSL                auto
DNS_sleep         66
DNS_alias_mode    no
Cache            no
Security        no
HTTP_Listen        http://0.0.0.0:80
HTTPS_Listen    https://0.0.0.0:443
HTTP_Backend    http://1.2.3.4:8080
HTTPS_Backend    https://1.2.3.4:8443
Set Crontab:
echo '*/15 * * * * root /usr/bin/vddos-autoadd panel directadmin apache' >> /etc/crontab
STEP 6: Config vDDoS Auto Switch
vDDoS Auto Switch is a addon support for vDDoS Proxy Protection - Automatically identifies overloaded websites and changes their Security Mode.
nano /vddos/auto-switch/setting.conf
# This is the default configuration for "sensor-switch.sh" and "vddos-autoswitch.sh"
hostname="vDDoS Master"                            #(Name this server, it will show up in Email notifications)
vddos_master_slave_mode="no"                    #(Turn on "yes" if your system has slave servers, want to sync affter switch like master)
backend_url_check="no"            #(Put the URL of the backend. Ex: https://1.1.1.1:8443/ (make sure Backend status response is "200"))
send_notifications="no"                        #(Turn on "yes" if you want receive notification)
smtp_server="smtps://smtp.gmail.com"        #(SMTP Server)
smtp_username="[email protected]"                #(Your Mail)
smtp_password="xxxxxxxxxxxxx"                 #(Get your Apps password for Gmail from https://security.google.com/settings/security/apppasswords)
send_notifications_to="[email protected]"        #(Your Email Address will receive notification)
maximum_allowable_delay_for_backend=2             #(Means: If Backend (status response "200") is slower than 2s, vDDoS will enable challenge mode)
maximum_allowable_delay_for_website=2             #(Means: If Website (status response "200") is slower than 2s, vDDoS will enable challenge mode)
default_switch_mode_not_attack="no"                #(Default Mode vDDoS use when it's not under attacked)
default_switch_mode_under_attack="high"            #(Default Mode vDDoS use when it's under attack)
default_waiting_time_to_release="60"            #(For example 60 minutes, release time from challenge)
Crontab vDDoS Auto Switch:
echo '*/5 * * * * root /usr/bin/vddos-autoswitch checkalldomain high' >> /etc/crontab
echo '0 */3 * * * root /usr/bin/vddos-switch allsite no && /usr/bin/vddos reload' >> /etc/crontab
echo '* * * * * root /usr/bin/vddos-sensor' >> /etc/crontab
More documentation:
https://github.com/duy13/vDDoS-Auto-Switch
I have experienced a few attacks and there was nothing on my equipment that would have mitigated it. Every time I have had to get the data center to mitigate it. I just don't understand how anything can be run on the server being attacked will help.
Basically, it helps you not to run over CPU, RAM, IO resources... as for NETWORK, of course you have to upgrade the network infrastructure, server's bandwidth. No software is installed on the server to help it increase network bandwidth
