Daniel-Doggy
- Nov 16, 2019
da update 8c3f499aab9e9b51feb3e1fcb07de4138c858f67
/usr/local/directadmin/data/users/{user}/skin_customizations/evolution/config.json file with us, where {user} is the admin or reseller account that does not work after upgrade.{"da:options/standard-2021-layout/active-widgets":"[\"WGT_ADDITIONAL_DOMAINS\",\"WGT_USER_BLOCKS\",\"WGT_DB\",\"WGT_EMAIL_POP\"]","da:options/standard-2021-layout/frequent-routes":"[[\"/user/messages\",3],[\"/admin/updates\",2]]","da:options/standard-2021-layout/navigation/type":"\"list\"","da:options/skin/layout":"\"standard2021\"","da:options/tables/density":"\"condensed\"","da:options/standard-2021-layout/list-menu-extended":"false","da:options/tables/ipp":"100"}
user_options.json should not have caused it. Reading the initial report I do not think it is related to Evolution customizations as well. The upgrade should not affect Ehnaced in any way. Without access to the server we can not investigate this further.2022:06:04-11:49:35: Socket write error: Unknown error: Connection reset by peer
2022:06:04-11:49:35: Error while sending file. Sent 50
2022:06:04-11:49:35: Error while sending file. Sent 65
2022:06:04-11:50:03: Socket write error: Unknown error: Connection reset by peer
2022:06:04-11:50:03: Error while sending file. Sent 57
Solution: more testing, less updates to accomodate.DA gets more updates than Windows 10, even little bugs like Windows 11..... Hotfixes nearly every few days......
Bring back the good old days, where DA was simple and had CB just to do updates via bash..... No Evo skin........ I know things need evolving (pun intended), just I just read about bugs every time I visit here....... Lucky I only have one active license now, so I don't log into DA frequently.
FWIW, why still have the Enhanced skin when most new features are Evo based......
Two step authentication is included in DirectAdmin.Please let me ask.
does directadmin login have 2 step verification function?
Is it possible to install 2-step verification via 3rd app for directadmin login?
Thank.
May you list the features that you are missing there?Curious if there's a roadmap for WP Manager to make it more competitive with the competition or if it's just going to be a smaller part to add some quality of life when not using something like softaculous? So far liking the changes, only missing a few more features before it replaces softaculous for me.
The main ones I would love to have is belowMay you list the features that you are missing there?
I completely agree.The main ones I would love to have is below
- Create staging domain (The main drawback of softalocus is you need to make the subdomain first, Would be amazing to have it as a 1 click and DA automatically make the subdomain)
- One-Click Backup/Restore (Just a bit of usability for end-users)
- View files in File Manager/ Redirect to File Manager (I know clicking the file path does this, but having it in a list or a row of buttons with backup, staging, update might be cleaner)
Nice to haves
- Select PHP Version
- See WP, Theme or Plugin update availability
- Plugin Sets or pre-configured themes
Hope you take the staging one on board if any, Would love to simplify the process to one click![]()
Nice to haves
It is already there,- One-Click Backup/Restore (Just a bit of usability for end-users)
