custom php_settings.json - change range to values
johannes
Is it possible to change a given range to a list of values?
Example: change range from
"max_input_vars" : {
"default" : 10000,
"type": "int",
"range" : [ 1, 100000 ]
to a list of values:
"default" : 10000,
"type": "list",
"values" : [
"8000",
"12000",
"16000",
"20000",
.. and if yes, is this valid for all range options?
try custom this file "/usr/local/directadmin/data/templates/php_settings.json"
As I wrote in my title "custom php_settings.json" I have already a custom php_settings.json.
My question is, if its allowed (or if its possible) to change a range to a list, when its a range in the original json.
Sorry, But it possible. From my testing in the past. That I don't want user Change Memory. I change type list into range, it working!
Also list to range posaible too, Because it template, it should work like a Dynamic System.
Besure you restart Directadmin after make change.
Sounds great, thanks for the info! Will try and report here.
