wemanageit
- Jun 12, 2022
As it says in the subject I am a new DA user, coming from CP for obvious reasons...
So I got my new server setup with DA, my hosting company provides DA licenses as part of the hosting...
I installed on my KVM Slice 2GB, using Ubuntu 20.04 (I don't speak Red Hat
hence using what I've used for the 20 years+ )
Did the install with the
Ok.. all good to go.. everything completed, CustomBuild too... its running and sitting there...
What I am after is a HOWTO, tutorials (NO! Videos! I don't watch videos!) on this... tutorials I find are about installing DA.. done that..
A couple of the questions I am after
1) I have a NEW domain to use for this host for its setup as the server name etc... ie: server.newdomain.cc , right now this set to: server-IP.da.direct
So where was this supposed to be set??? Or get set????
How to correct and reset for DA etc..
This likely is something that if I have to guess, many if not 99.9999% of the tutorial on installing DA omit that the hostname of the box needs to be set before hand??? And other settings that need to be set...
I am not progressing much further as I have a funny feeling this will require a wipe/resetup/install to correct...
2) SSL for the DA portal????? How to setup???? After I the server name is corrected.. Lots of things about setting SSL for new accounts..., not the DA portal itself...
The big thing I am after:
Tutorials and HOWTOs for those coming from CP and setting of Resellers etc....is one of the big things I am after.. after getting the name and more security on the DA Portal itself...
Thanks in advance.
bash <(curl -Ss https://www.directadmin.com/setup.sh) auto
Thanks in advance.
