My WordPress website was hacked
Johnws2022
Dear Sir,
My DirectAdmin control panel is easily hacked even I have implemented 2FA using:
1. Google Authenticator
2. Security question
together; the hackers still manages to enter my server and modify my core website's files.
Is there any way of stop the hackers completely.
Many thanks in advance.
Regards
Thon
A Directadmin control panel is certainly not easily hacked.
If some hacker manages to modify core website files, most likely you got a compromised FTP account or a compromised theme, addon or something else on the website itself.
Another possibility is that they compromised your server and have root access. That is not very likely, but also not impossible.
Yes, but you first have to figure out how they manage to change your core websites.
For that, you need SSH access to our server and check various logfiles at the time you see something changed.
Also it's a good start to change all your passwords, so not only DA pass and 2FA, but also your FTP password(s) and if the website has passwords (like Wordpress) then change those passwords too.
Install malware detection, which can also often detect malicous scripts. So install Maldetect.
Some information:
Do they change your core files again? Check your server logs to see what was going on and when and most likely you will also find out how.
Dear Sir,
Thank you for great support.
FTP and DA control panel use the same 2FA. Of course they managed to get pass through 2FA to change core files of my websites. They cant access SSS as I use a different port number.
The reason for the above is when I use Wordfence plugin to scan which files have been modified, then I fix them; then I change password for DA and 2FA, it takes a few days or a week before the hackers managed to access my server to modify core files again. If they access my server using SSH, they should be able to do so straight away.
Is there any way of stopping the hackers completely.
Regards
Thon
The problem with trying to block them completely is you still don’t know how they are getting in. Until you find out how they are getting in, you will never block them. The best you can do is sift through ALL of the log files to identify their ingress and then mitigate it. It could be an unknown open port or a service vulnerability or any number of things.
What specific files are being modified? Just files within your account's home directory? Or files that exist within the server's root?
What script are you using to manage your website? Is the login to that script protected by 2FA?
What version of the script are you using? What plugins are you using? What theme are you using? Are all of those being kept up to date? When were they last updated by their developers? A plugin that was last updated in 2015 may be up to date, but that doesn't mean it's secure.
Does DirectAdmin have 2FA for FTP? From a fundamental level, I don't know how that would work.
Are you sure your computer, devices, and networks don't have any malware or keyloggers running on them?
2FA and Security Question will work only for :2222 Panel not apply to other service.
Good passwords, and changing it regularly is still the most important thing.
I rotate passwords every month or so.
Dear Sir,
I can confirm that I have used 2FA mentioned above for DA and FTP.
All my websites on the server with DA are Wordpress. The hackers modify different core files of all my WP website on that server like:
index.php
migration.php
jquery
and so on.
I believe they entered my server via FTP of DirectAdmin which use 2FA stated above.
Is there any way of allowing only my IP to access DA and its FTP (File Manager)?
Cheers
Dear Sir,
index.php
migration.php
jquery
and so on.
Cheers
Sounds like your wordpress site is hacked, not directadmin.
Make sure everything is up to date (wp themes, wp plugins), change passwords on wordpress etc.
2FA does nothing with FTP. Or do you mean File Manager within DirectAdmin?
As suggested before, check for vulnerable plugins with Wordfence. Setup Web Application Firewall with Wordfence and follow it’s suggestions. Check for unwanted php files in the uploads directory and make sure the uploads folder is not allowed to execute PHP scripts.
For us it’s a wild guess because we don’t have a URL:)
Like others already said, there is no existing 2FA method for FTP.
As in my first reply, I already told that it is most likely a leak plugin, addon or theme. Even if it might be up to date, there can still be security issues with it.
Seems you have not started to use the tips that I and others already gave.
1.) Check your logfiles to see how theyu got in
2.) Install Maldetect and do a scan on your website!
3.) What Erulezz says, add that too, the Wordfence plugin.
Yes, sir. The hackers accessed my website via File Manager of DirectAdmin.
Thon
Can you show part of the log which prooves that?
Also you might want to scan your pc for malware (adwcleaner and afterwards Malware Bytes) and then change your mail password too.
Sorry to say but It seems to me that your WP is hacked because of outdated theme or plugin.
We always install standard Wordfence on all of Worpress sites, stops lot of attacks at forehand.
If the DA panel has an vulnerability then thousand of sites would be compromised right now and the internet would be full of it, but it isn't
So you didn't solved then the real problem only pass and changed back some files, but the "open door (s)" you didn't closed at all?
You also didn't use the forum / support rules, while you didn't post your OS and versions used, the versions of DA and the versions of the APP as WP ( and plugins) you using and where the hacking takes places at the first time.
LOG FILES with some more info's you also forget to post!
So how should users of this Forum and DA help you whithout all those info's ??
Also you didn't post / say what your User rights are for those files an directorys, while lot of users set some to 777 or so, to have some plugings or WP working ??
Oyea and as @Richard G mentioned the devices you have access with could be hacked (to). ( or even not hacked but another Person who have access in real there. ( remote or on location) ( Yes for the 2FA if they managed that then more then 1 device, so probably problem with user rights or plugins / addons on server)
Some people do use for their 2fa a kind of forward for those mesages to same device where they login with, then it is nomore 2FA.
Dear Sir,
Thank you for your advice.
How can I get log file? via SSH or in DA's control panel?
Cheers
