CrazyFrog
- Aug 28, 2019
Today a vulnerability in Dovecot (pop3/imap server) was announced. In insecure configurations, it could allow users to become Dovecot 'master users'.
Is DirectAdmin affected by this? I am not so keen on the internals of how DA handles authentication for Dovecot. Maybe DA is unaffected by this problem. The Dovecot committer thinks insecure configurations should be not common. I hope somebody with more experience in DA can look at this issue. If we are vulnerable, I guess we'll have to wait for a new Dovecot release and update it ASAP...
Edit: fixed vulnerable version and component.Affected product: Dovecot IMAP Server
Internal reference: DOV-5320
Vulnerability type: Improper Access Control (CWE-284)
Vulnerable version: 2.2 and newer
Vulnerable component: auth
Report confidence: Confirmed
Solution status: Fixed in main
Researcher credits: Julian Brook (julezman)
Vendor notification: 2022-05-06
CVE reference: CVE-2022-30550
CVSS: 6.8 (CVSS:3.1/AV:N/AC:H/PR:L/UI:N/S:U/C:H/I:H/A:N)
Vulnerability Details:
When two passdb configuration entries exist in Dovecot configuration, which have the same driver and args settings, the incorrect username_filter and mechanism settings can be applied to passdb definitions. These incorrectly applied settings can lead to an unintended security configuration and can permit privilege escalation with certain configurations involving master user authentication.
Dovecot documentation does not advise against the use of passdb definitions which have the same driver and args settings. One such configuration would be where an administrator wishes to use the same pam configuration or passwd file for both normal and master users but use the username_filter setting to restrict which of the users is able to be a master user.
Risk:
If same passwd file or PAM is used for both normal and master users, it is possible for attacker to become master user.
Workaround:
Always authenticate master users from different source than regular users, e.g. using a separate passwd file. Alternatively, you can use global ACLs to ensure that only legimate master users have priviledged access.
Fix:
This has been fixed in main branch. See https://github.com/dovecot/core/compare/7bad6a24^..a1022072.patch
