custom webalizer stats folder
BuGoFf
Belgium
i have a customer who uses /stats/ as a folder for his own CMS, is there a way to update the stats folder for all users so directadmin doesn't complains about a suspicious stats folder?
Kr,
Bram
In directadmin.conf set:
webalizer=0
and restart directadmin.
Same way you can also set:
awstats=0
to disable awstats too.
But this is for whole server, or do you only need for 1 user?
Thanks for Your continuous support, Richard. As a reseller only, i am unable to find directadmin.conf file. Nor in particular DA resold account. Maybe someone will mention how to disable it as user or maybe such feature is yet to be created.
You're welcome @wdc.
In the past, it was not possible to disable webalizer on a per user base.
If I'm correct, that one didn't change, while for awstats there is a switch.
Might be a good idea to put that as request in the feedback forum.
For now, as far as I know, the only option is to ask the admin to disable webalizer globally (if he wants it) and leave awstats switchable per user like it can be done now. Imho Awstats is nicer than webalizer anyway. ;)
And more accurate
