I installed DirectAdmin on a clean AlmaLinux 8 installation using the following commands
sudo dnf update
sudo dnf install epel-release
bash <(curl -Ss https://www.directadmin.com/setup.sh || wget -O - https://www.directadmin.com/setup.sh) auto
After I logged in into DirectAdmin interface I added the CustomBuild Plugin 2.0 from http://www.custombuild.eu/plugin/custombuild.tar.gz
but Custom Build Plugin 2.0 wont work as you can see in the attached screenshot
Should I change something to a config file ?
sudo dnf update
