Check Redis and Memcached are on directadmin or not?
cacanhmini
I'm getting the following error on my WP site:
The AMP plugin performs at its best when persistent object cache is enabled. Persistent object caching is used to more effectively store image dimensions and parsed CSS using a caching backend rather than using the options table in the database.
Please check with your host for what persistent caching services are available.
According to the documentation I have to enable Redis and Memcached on the server then install the Redis and Memcached plugin.
If anyone knows how to fix this please guide me. Thank.
That is not an error but a notice. So you don't have to enable Redis and Memcached. It's only stating that the AMP plugin works at its best with Persistent object caching.
So you can safely ignore it.
If you still want to use redis:
For memcached:
But you probably shouldn't use both. I'm not sure. I would start with Redis.
Thank Richard G,
Ready for me to ask. Do you know any plugin that supports easy-to-use forum creation and registration on wordpress?
Thank.
