Ionclube loaders for php 8.1
Richard G
Maastricht
They are released since today for Linux.
5TH AUGUST UPDATE: Online Encoder has been updated with PHP 8.1 encoding support. Version 12.0.0 Loaders now available (Linux only for now, other operating systems will follow soon after).
V.12.0.1 was released yestersay.
Please check it again.
Production Loaders​
OS/PlatformPackagesVersionRelease Date
Linux (32 bits) Includes ionCube 24 support tar.gz zip 12.0.1 2022-08-12 UPDATED
Linux (64 bits) Includes ionCube 24 support tar.gz zip 12.0.1 2022-08-12 UPDATED
Please tell me what that means.
The archive is there and ready to be downloaded.
I can find the support for 8.1 there.
Can somebody explain to me?
It's a link, you had to click on it. Then you had seen a post stating that is was now available in custombuild.
Ahh, missed that point.
Thanks.
I guess now I can use PHP 8.1.9 for my Blesta if only they have supported PHP 8.1.
If your Blesta supports the new v12 ioncube loader then yes you can.
What does that mean?
They have to update their codes for ioncube v12.0.1?
After they updated the code, will the code be still usable for ioncube prior v.12?
It does not make sense for me.
Please explain to me. :)
Only if Blesta doesn't work with v12, I don't know if it does or doesn't.
If it works, it's fine. But maybe it's good to ask them before you upgrade to php 8.1 then if you don't know either.
I don't know if they can build in a backward compatibility if they update their code (if needed). You have to ask that on the Blesta support forums.
