Update MariaDB 10.4.25 to 10.4.26 & 10.5.16 to 10.5.17 failed
toktokcity
The Netherlands
Normally running updates whitout any problems. But now the update failed and version is still .25. The update disappeared from Custombuild.
Make complete
Packaging mariadb-10.4.26...
CPack3: Create package using TGZ
CPack3: Install projects
CPack3: - Install project: MySQL []
CPack3: - package: /usr/local/directadmin/custombuild/mariadb-10.4.26/mariadb-10.4.26-linux-x86_64.tar.gz generated.
Moving mariadb-10.4.26-*.tar.gz to /usr/local/directadmin/custombuild ...
Done.
Found created package: mariadb-10.4.26-linux-x86_64.tar.gz
tar: write error
Stopping mysqld ...
Service didn't get stopped, sleeping for 20 secs and re-trying ...
Stopping mysqld ...
Removed symlink /etc/systemd/system/multi-user.target.wants/mariadb.service.
Removed symlink /etc/systemd/system/mysql.service.
Removed symlink /etc/systemd/system/mysqld.service.
mv: cannot stat '/etc/systemd/system/mysql.service': No such file or directory
Failed to execute operation: No such file or directory
Linking /usr/local/mysql/bin/aria_chk -> /usr/local/bin/aria_chk...
Linking /usr/local/mysql/bin/aria_dump_log -> /usr/local/bin/aria_dump_log...
Linking /usr/local/mysql/bin/aria_ftdump -> /usr/local/bin/aria_ftdump...
Linking /usr/local/mysql/bin/aria_pack -> /usr/local/bin/aria_pack...
Linking /usr/local/mysql/bin/aria_read_log -> /usr/local/bin/aria_read_log...
Linking /usr/local/mysql/bin/galera_new_cluster -> /usr/local/bin/galera_new_cluster...
Linking /usr/local/mysql/bin/galera_recovery -> /usr/local/bin/galera_recovery...
Linking /usr/local/mysql/bin/innochecksum -> /usr/local/bin/innochecksum...
Linking /usr/local/mysql/bin/mariabackup -> /usr/local/bin/mariabackup...
Linking /usr/local/mysql/bin/mariadb -> /usr/local/bin/mariadb...
Linking /usr/local/mysql/bin/mariadb-access -> /usr/local/bin/mariadb-access...
Linking /usr/local/mysql/bin/mariadb-admin -> /usr/local/bin/mariadb-admin...
Linking /usr/local/mysql/bin/mariadb-backup -> /usr/local/bin/mariadb-backup...
Linking /usr/local/mysql/bin/mariadb-binlog -> /usr/local/bin/mariadb-binlog...
Linking /usr/local/mysql/bin/mariadb-check -> /usr/local/bin/mariadb-check...
Linking /usr/local/mysql/bin/mariadb-client-test -> /usr/local/bin/mariadb-client-test...
Linking /usr/local/mysql/bin/mariadb-convert-table-format -> /usr/local/bin/mariadb-convert-table-format...
Linking /usr/local/mysql/bin/mariadb-dump -> /usr/local/bin/mariadb-dump...
Linking /usr/local/mysql/bin/mariadb-dumpslow -> /usr/local/bin/mariadb-dumpslow...
Linking /usr/local/mysql/bin/mariadb-find-rows -> /usr/local/bin/mariadb-find-rows...
Linking /usr/local/mysql/bin/mariadb-fix-extensions -> /usr/local/bin/mariadb-fix-extensions...
Linking /usr/local/mysql/bin/mariadb-hotcopy -> /usr/local/bin/mariadb-hotcopy...
Linking /usr/local/mysql/bin/mariadb-import -> /usr/local/bin/mariadb-import...
Linking /usr/local/mysql/bin/mariadb-plugin -> /usr/local/bin/mariadb-plugin...
Linking /usr/local/mysql/bin/mariadb-secure-installation -> /usr/local/bin/mariadb-secure-installation...
Linking /usr/local/mysql/bin/mariadb-service-convert -> /usr/local/bin/mariadb-service-convert...
Linking /usr/local/mysql/bin/mariadb-setpermission -> /usr/local/bin/mariadb-setpermission...
Linking /usr/local/mysql/bin/mariadb-show -> /usr/local/bin/mariadb-show...
Linking /usr/local/mysql/bin/mariadb-slap -> /usr/local/bin/mariadb-slap...
Linking /usr/local/mysql/bin/mariadb-test -> /usr/local/bin/mariadb-test...
Linking /usr/local/mysql/bin/mariadb-tzinfo-to-sql -> /usr/local/bin/mariadb-tzinfo-to-sql...
Linking /usr/local/mysql/bin/mariadb-upgrade -> /usr/local/bin/mariadb-upgrade...
Linking /usr/local/mysql/bin/mariadb-waitpid -> /usr/local/bin/mariadb-waitpid...
Linking /usr/local/mysql/bin/mariadb_config -> /usr/local/bin/mariadb_config...
Linking /usr/local/mysql/bin/mariadbd -> /usr/local/bin/mariadbd...
Linking /usr/local/mysql/bin/mariadbd-multi -> /usr/local/bin/mariadbd-multi...
Linking /usr/local/mysql/bin/mariadbd-safe -> /usr/local/bin/mariadbd-safe...
Linking /usr/local/mysql/bin/mariadbd-safe-helper -> /usr/local/bin/mariadbd-safe-helper...
Linking /usr/local/mysql/bin/mbstream -> /usr/local/bin/mbstream...
Linking /usr/local/mysql/bin/msql2mysql -> /usr/local/bin/msql2mysql...
Linking /usr/local/mysql/bin/my_print_defaults -> /usr/local/bin/my_print_defaults...
Linking /usr/local/mysql/bin/myisam_ftdump -> /usr/local/bin/myisam_ftdump...
Linking /usr/local/mysql/bin/myisamchk -> /usr/local/bin/myisamchk...
Linking /usr/local/mysql/bin/myisamlog -> /usr/local/bin/myisamlog...
Linking /usr/local/mysql/bin/myisampack -> /usr/local/bin/myisampack...
Linking /usr/local/mysql/bin/mysql -> /usr/local/bin/mysql...
Linking /usr/local/mysql/bin/mysql_client_test -> /usr/local/bin/mysql_client_test...
Linking /usr/local/mysql/bin/mysql_config -> /usr/local/bin/mysql_config...
Linking /usr/local/mysql/bin/mysql_convert_table_format -> /usr/local/bin/mysql_convert_table_format...
Linking /usr/local/mysql/bin/mysql_find_rows -> /usr/local/bin/mysql_find_rows...
Linking /usr/local/mysql/bin/mysql_fix_extensions -> /usr/local/bin/mysql_fix_extensions...
Linking /usr/local/mysql/bin/mysql_plugin -> /usr/local/bin/mysql_plugin...
Linking /usr/local/mysql/bin/mysql_secure_installation -> /usr/local/bin/mysql_secure_installation...
Linking /usr/local/mysql/bin/mysql_setpermission -> /usr/local/bin/mysql_setpermission...
Linking /usr/local/mysql/bin/mysql_tzinfo_to_sql -> /usr/local/bin/mysql_tzinfo_to_sql...
Linking /usr/local/mysql/bin/mysql_upgrade -> /usr/local/bin/mysql_upgrade...
Linking /usr/local/mysql/bin/mysql_waitpid -> /usr/local/bin/mysql_waitpid...
Linking /usr/local/mysql/bin/mysqlaccess -> /usr/local/bin/mysqlaccess...
Linking /usr/local/mysql/bin/mysqladmin -> /usr/local/bin/mysqladmin...
Linking /usr/local/mysql/bin/mysqlbinlog -> /usr/local/bin/mysqlbinlog...
Linking /usr/local/mysql/bin/mysqlcheck -> /usr/local/bin/mysqlcheck...
Linking /usr/local/mysql/bin/mysqld -> /usr/local/bin/mysqld...
Linking /usr/local/mysql/bin/mysqld_multi -> /usr/local/bin/mysqld_multi...
Linking /usr/local/mysql/bin/mysqld_safe -> /usr/local/bin/mysqld_safe...
Linking /usr/local/mysql/bin/mysqld_safe_helper -> /usr/local/bin/mysqld_safe_helper...
Linking /usr/local/mysql/bin/mysqldump -> /usr/local/bin/mysqldump...
Linking /usr/local/mysql/bin/mysqldumpslow -> /usr/local/bin/mysqldumpslow...
Linking /usr/local/mysql/bin/mysqlhotcopy -> /usr/local/bin/mysqlhotcopy...
Linking /usr/local/mysql/bin/mysqlimport -> /usr/local/bin/mysqlimport...
Linking /usr/local/mysql/bin/mysqlshow -> /usr/local/bin/mysqlshow...
Linking /usr/local/mysql/bin/mysqlslap -> /usr/local/bin/mysqlslap...
Linking /usr/local/mysql/bin/mysqltest -> /usr/local/bin/mysqltest...
Linking /usr/local/mysql/bin/mytop -> /usr/local/bin/mytop...
Linking /usr/local/mysql/bin/perror -> /usr/local/bin/perror...
Linking /usr/local/mysql/bin/replace -> /usr/local/bin/replace...
Linking /usr/local/mysql/bin/resolve_stack_dump -> /usr/local/bin/resolve_stack_dump...
Linking /usr/local/mysql/bin/resolveip -> /usr/local/bin/resolveip...
Linking /usr/local/mysql/bin/wsrep_sst_backup -> /usr/local/bin/wsrep_sst_backup...
Linking /usr/local/mysql/bin/wsrep_sst_common -> /usr/local/bin/wsrep_sst_common...
Linking /usr/local/mysql/bin/wsrep_sst_mariabackup -> /usr/local/bin/wsrep_sst_mariabackup...
Linking /usr/local/mysql/bin/wsrep_sst_mysqldump -> /usr/local/bin/wsrep_sst_mysqldump...
Linking /usr/local/mysql/bin/wsrep_sst_rsync -> /usr/local/bin/wsrep_sst_rsync...
Linking /usr/local/mysql/bin/wsrep_sst_rsync_wan -> /usr/local/bin/wsrep_sst_rsync_wan...
Ensuring local-infile is disabled for security reasons in MySQL configuration file...
Giving mysqld a few seconds to start up...
Giving mysqld a another few seconds to start up...
Giving mysqld last 20 seconds to start up...
Reading datadir from the MariaDB server failed. Got the following error when executing the 'mysql' command line client
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
FATAL ERROR: Upgrade failed
[1mError running '/usr/local/mysql/bin/mysql_upgrade --defaults-extra-file=/usr/local/directadmin/conf/my.cnf --skip-version-check'(B[m
Restarting MySQL.
Installation completed.
Update: problem on two different servers, one running MariaDB 10.4 and one 10.5
Done.
tar: write error
Do you have enough disk space available in your /usr partition? You should have enough to both move the tar.gz file there and extract it, so it could be a few GB.
Done.
tar: write error
Could you try removing /usr/local/directadmin/custombuild/mariadb-10.4.26-linux-x86_64* (both the .tar.gz if it exists and the folder) and building mariadb again?
I did remove the file from the CustomBuild directory, but the update is not coming back in CustomBuild.
Same problem also occured on another server by updating from 10.5.16 to 10.5.17.
Restarting MySQL.
Hmm... is your DA / Custombuild upgraded to the latest version?
Is your MySQL datadir /home/mysql by any chance? See also:
What does
./build tells the version of MariaDB is 10.4.26.
System information in DirectAdmin displays
Going to reboot the system tonight and see which DB it will start.
What does
mysqld --version
say?
What does
mysqld --version
say?
mysqld Ver 10.4.26-MariaDB for Linux on x86_64 (Source distribution)
mysqld Ver 10.5.17-MariaDB for Linux on x86_64 (Source distribution)
PMA is also telling me it is working on the updated version. So, although I got errors telling me the update failed, it is running.
I am a bit lost in confusion right now :-|
Hmm not sure, looks like you are running the latest version but Directadmin is showing the unupdated version. Not sure where it's getting the System Information input from.
Try:
./build mysql
If it doesn't help - feel free to PM me.
Try:
./build mysql
I think the point of wtptrs is correct, after the errors, the system looks to be updated and is running, but DirectAdmin didn't notice this and is still displaying the old version.
Like smtalk said... send him a pm.
We also did the Mariadb 10.4.25 to 10.4.26 but in our case DA does display the correct version.
So maybe there is some small adjustment needed, but smtalk can see quickly why the display in DA is wrong.
After update 10.4.26 -> 10.4.27 on one server failed:
Please help
Bash:
[root@cursadweb-04 custombuild]# ./build mysql
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
Error: Nothing to do
######################################################################## 100.0%
Found /usr/local/directadmin/custombuild/mysql/MariaDB-client-10.4.27-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-devel-10.4.27-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-server-10.4.27-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-shared-10.4.27-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-common-10.4.27-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-compat-10.4.27-1.el7.centos.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/MariaDB-backup-10.4.27-1.el7.centos.x86_64.rpm
Installing dependencies...
Installing libjemalloc...
Found /usr/local/directadmin/custombuild/mysql/jemalloc-3.6.0-1.el7.x86_64.rpm
Found /usr/local/directadmin/custombuild/mysql/jemalloc-devel-3.6.0-1.el7.x86_64.rpm
warning: /usr/local/directadmin/custombuild/mysql/jemalloc-3.6.0-1.el7.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 1bb943db: NOKEY
Preparing...                          ########################################
Updating / installing...
jemalloc-3.6.0-1.el7                  ########################################
jemalloc-devel-3.6.0-1.el7            ########################################
Installing galera...
Found /usr/local/directadmin/custombuild/mysql/galera-4-26.4.8-1.el7.centos.x86_64.rpm
warning: /usr/local/directadmin/custombuild/mysql/galera-4-26.4.8-1.el7.centos.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 1bb943db: NOKEY
galera-4-26.4.8-1.el7.centos          ########################################
Stopping mysqld ...
Updating MariaDB 10.4.27 to 10.4.27
warning: MariaDB-client-10.4.27-1.el7.centos.x86_64.rpm: Header V4 DSA/SHA1 Signature, key ID 1bb943db: NOKEY
MariaDB-compat-10.4.27-1.el7.centos   ########################################
MariaDB-common-10.4.27-1.el7.centos   ########################################
MariaDB-client-10.4.27-1.el7.centos   ########################################
MariaDB-shared-10.4.27-1.el7.centos   ########################################
MariaDB-devel-10.4.27-1.el7.centos    ########################################
MariaDB-server-10.4.27-1.el7.centos   ########################################
MariaDB-backup-10.4.27-1.el7.centos   ########################################
Created symlink from /etc/systemd/system/mysql.service to /etc/systemd/system/mariadb.service.
Created symlink from /etc/systemd/system/mysqld.service to /etc/systemd/system/mariadb.service.
Job for mariadb.service failed because a fatal signal was delivered to the control process. See "systemctl status mariadb.service" and "journalctl -xe" for details.
/usr/bin/mysqlcheck: Got error: 2002: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2) when trying to connect
cp: '/usr/lib/libmysqlclient.so' and '/usr/lib/mysql/libmysqlclient.so' are the same file
Restarting MySQL.
