Help! add CNAME record to domain DNS
Hi everyone,
I build a website using easystore, but getting a problem when connecting to my domain.
I need to add CNAME record to my domain DNS. But the result always add my domain name at the back of the record causing easystore server not able to verify / detect the correct CNAME.
https://dnschecker.org/#CNAME/_acme-challenge.duniabangunan.id
Add a trailing dot . after the domain name you highlighted in red and you should be good (the record change can take a while to become active).
As you can see in your Directadmin DNS zone, except for TXT records, all your other records (i.e. mx.zoho.com.) end in a dot, if you don't do this your domain name will be automatically added at the end of your record.
