Dettol
- Sep 26, 2022
You right:@Dettol, PHP7.4.32
is shipped with DA current upgradeversions.txt
file. Old CustomBuild available on the files.directadmin.com mirrors is still having PHP 7.4.30. I think something on your system is pulling versions.txt from files servers.
Code:# da v DirectAdmin v.1.643 8c5c161f99047c9098e7bf4f89005929dea3942e # grep php74 /usr/local/directadmin/custombuild/versions.txt php74:7.4.32: # curl -s https://files.directadmin.com/services/custombuild/versions.txt | grep php74 php74:7.4.30:
So I have two hypothesis to explain such behaviour:
1. You are still having old Custombuild script version (that still pulls versions.txt from mirrors). Please check if checksums match:
Code:# md5sum /usr/local/directadmin/custombuild/build /usr/local/directadmin/custombuild/versions.txt b8f5628041c6117c176ed3695b90f5d0 /usr/local/directadmin/custombuild/build a32e7f4f677a6bc15d9dd0746512c26a /usr/local/directadmin/custombuild/versions.txt
2. You have some cronjob or other 3rd party tool that automatically pulls versions.txt from mirrors.
543c5d8d904e9b38a0b1498c9328c46d /usr/local/directadmin/custombuild/build
10376b504020464fd6aeed5ce6b45064 /usr/local/directadmin/custombuild/versions.txt
but I clicked "Update Custombuild" or "Update CustomBuild Script & Versions (only)
and staill same
##O#-#
########################################################## 81.0%
######################################################################## 100.0%
Extracting custombuild.tar.gz...
##O#-#
