Roundcube connection refused, Please help me
nutnitid
Please help me
Why did you build roundcube this way?
What Linux distro and version are you using?
Did you try removing roundcube totally and do a totally fresh roundcube install?
Linux version 3.10.0-1160.76.1.el7.x86_64 ([email protected]) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-44) (GCC) ) #1 SMP Wed Aug 10 16:21:17
I upgraded the version via directadmin.
and it encountered a problem, can't use roundcube
So I'm trying to figure out how to fix it.
I solved it 2 days ago.
Starting from mysql there was a problem and I was able to fix it.
but roundcube can't connect database
I've tried reinstalling it in a number of ways, but it's only stuck here.
Hmmz...
RoundCube 1.6.0 cannot run on php 7.3 or older
Maybe it's because you have older php versions running that you can't build the 1.6.0. You have to keep with 1.5.3.
Also check your options.conf for this setting:
mysql_force_compile=no
so if you have this set to yes, change it to no.
Is roundcube 1.5.3 working?
I tried setting Still can't use it bro.
sued that it was unable to connect to the database.
you from thailand ?
I suggest to rebuild mysql after set "mysql_force_compile=no" if still not work, trying remove/rename da_roundcube database to force rebuild all thing about roundcube
You might best send in a ticket, seems there probably is an issue/bug.
Seen the same here:
you from thailand ?
yes brother
And I've tried all of them according to your brother.
but still can't fix it
I am currently installing a new server and will be migrating to new server instead
Because phpmyadmin is currently not available as well.
I tested it, if you have more than 1 php select "no" leave only 1 and try restart mysql again and try to install webmail again.
Seen the same here:
I also have the same during backup, how to fix it?
