DirectAdmin 1.644 has been released
Also getting the following when accessing CSF.
Security Error: No valid session key
Information saved to [/var/lib/csf/da1666134737.error]
Never had this error before the update and I check this all the time.
I can also confirm that logging out and going back in "fixes" the problem.
Logging out and back in is not fixing for me. Needed to delete session files in /usr/local/directadmin/data/sessions/
Thing is that I did delete yesterday, and today the issue is still appearing. Really annoyed with recent DA updates!
A new build 2b7a1efcb4d7ac7f062a12a5a908c77c5279e230 is released with the following changes:
  • Fixed Evolution reseller password change issue, thanks @paulonichio.
  • Fixed Evolution reverting to refreshed theme on reload.
I'm on the current branch and files2 and no update, even tried files. ?‍♂️
So glad I only have one active license now, all these issues every update.....
Even with the hotfix applied we are getting an error with DirectAdmin when changing a password for an user account:
directadmin is not in the allowed list: CMD_API_USER_PASSWD, CMD_USER_PASSWD, HTM_USER_PASSWD, admin/passwords, admin/users, reseller/passwords
Maybe still old version? v1.644 (76dbc3f) to v1.644 (7258c4d)
@HHawk79 hmm, if the hot-fix were applied the error message would be slightly different, it would include reseller/users in the list. I think the hot-fix is not installed on the server. Are you sure DA reports 2b7a1efcb4d7ac7f062a12a5a908c77c5279e230 as the current build ID?
DirectAdmin v.1.644 7258c4dea64c9f5b910f80a85e756146a02c728e
Seems I have the older version still. :S
Same issue here. Logging in and out does not fix the problem.
@Remco00 did you try reinstall CSF? it updated? DA latest version too?
Latest versions. Happens with all installed plugins. First time we've seen this behavior when opening the control panel in a desktop browser. There were no session files present in /usr/local/directadmin/data/sessions/. Right now the plugins open without error message but the error seems to appear randomly. Very strange.
New DA build c23594a3fd76908775c2e304528225a7f8806cc6 resolves the issue of new messages bubble not being updated without refresh, thanks @paulonichio.
I am still not sure about the CSF plugin session issues reported, we can not reproduce the issue locally so any additional feedback on how to trigger them would be really appreciated. Thanks everyone.
Perhaps something similar could be done to the number of available updates (in brackets) listed after the CustomBuild menu option. This number remains visible even though the updates have been performed.
CSF plugin session issues is related to an IP address change on your network or if you switch from Wifi to 5G.
clear your browser cache or log out and login again.
The password issue for users is resolved now, but also having the CSF problems. Only seeing the issue with Firefox over here.
so one of you guy can create ticket for Session Problem.
As you know, DA team need to know how to debug this problem.
After the update c23594a3fd76908775c2e304528225a7f8806cc6 the option to switch between accounts that was in the side menu disappeared, in this way it was much easier to switch from one account to another, now one must exit and search for it again.
(Attached screenshot where that option was)
  • Like
Reactions: fln
same issue with icons grid layout, master login is missing
  • Like
Reactions: fln
