[Exim order issue] The bad_sender_hosts_ip does not work with cidr's?
The advantage is less resources if I'm not mistaken. The CSF deny list creates iptables lines which are always loaded, so using resources.
CSf is slowing down things for sure if ranges or even country lists , it al;so seems to depend on the host network you are in while we have had before a vps n o problems after move to other hoster ( takeover) from old one it was a problem! IN logs more errors time outs and so on.
Edit:
After removing , disabling the ip list country's problem was gone then
No it's not pushed yet and not present in changelog either, so at the moment it won't be updated by doing a build update either.
Which is also the reason I did not marked this thread as solved yet.
You should be using files.directadmin.com,
DA support made the mistake themselfs by mentioning files1 in post #12. But you're right. However, it's also not pushed on files, neither on the changelog there. So I guess we will still have to wait a bit.
Not that I use it, but the 4.5.43 update is certainly there for me.
Alpha 1.6.45 (ac28461768425719b8f9f661ca2564e67cbcd852) already has it
Stable 1.6.44 (2138cff12eb6d60eec6bde18b2bf38b208f9ae51) does not
So i'm assuming that they released it for testing, and once verified will move to stable. I didn't check any other releases.
It's there in the files.directadmin.com directory but not pushed yet, at least not in current, and it's not in the changelog yet, that stops with 4.5.42.
So I think @cjd is right and they released it for testing and it will be pushed to current and stable later on.
