Bug updating MySQL
Kurogane
When is upgrading MySQL give this error.
Updating MariaDB.
Dumping database da_roundcube
Dumping database user1_user1
Dumping database user2_user2
Dumping database user3_user3
Dumping database mysql
Reading package lists...
Building dependency tree...
Reading state information...
E: Unable to locate package rpcsvc-proto
#=#=# ##=#=-# ##-=#=-# # #-=#=-# # #-=#=- # # #-=O#- # # #=O#- # # #=O=# # # #=O=-# # # -#O=-# # # -=#=- # # # -=O#- # # #-=O#- # # #=O=# # #
tar: write error
First, that package not exist in Debian 10/11. i'm not sure if because that package can't tar the backup, says write error but i not think is because a permission issue if not something else causing this problem, maybe because package error.
Looks like I have some related issue (but also URL returned error: 404).
DirectAdmin version: 1.644
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
Platform: KVM
NameCurrent VersionAvailable Version
MySQL
5.7.395.7.40
Executing process​
known bug, or do I have to do some magic to fix this.
Let me know. Many thanks,
Mek.
Hi Active8,
Great thanks, which file do I have to edit, then I give it a try.
Grtz,
Mek.
change download server to files.directadmin.com
I think I found it, It's the file: /usr/local/directadmin/custombuild/options.conf
and there change: downloadserver=files2.directadmin.com to > downloadserver=files.directadmin.com
But also editable in the GUI under:
CustomBuild > Edit Options > downloadserver > files.directadmin.com​
Looks like this has not been forced with an earlier update from DirectAdmin.
I read some info about it in release: 1.645. but the current release is: 1.644.
Release notes tell something about it, not 100% sure this is related:
Single files.directadmin.com download mirror custombuild improved​
CustomBuild has set_fastest, set_fastest_quiet, unofficial_mirrors and downloadmirror options removed. It always uses files.directadmin.com from now on, which is served by CloudFlare and uses CDN.
Grtz,
Mek.
Thanks, all. This fixed it for me as well. I just had to remember the commands lines:
./build update ./build
