Exchange Mail - Connection Timeout
evonet
Hello friends,
I am having an interesting problem.
My server can send mail to other email providers without a problem.
25. My port is open.
When I try to send mail to Exchange Online users, it says in the exim logs:
domain-com.mail.protection.outlook.com [104.47.11.74] Connection timed out
I contacted Microsoft and they said my ip address is not on a blacklist.
Where do you think the problem is? I need your help.
The result is as in the picture.
So block not from your side, ask who owns 104.44.42.222, it's microsoft. You can send them this screen.
as you provided - traffic brokes after this IP, so it's last who receives your traffic and this IP belongs to microsoft, you can check WHOIS for this IP
I've got on my side:
# traceroute -I 104.47.11.74
traceroute to 104.47.11.74 (104.47.11.74), 30 hops max, 60 byte packets
 1  * * *
 2  10.80.9.0 (10.80.9.0)  1.073 ms  1.060 ms  1.060 ms
 3  138.197.249.104 (138.197.249.104)  1.142 ms  1.143 ms  1.141 ms
 4  138.197.251.130 (138.197.251.130)  1.039 ms  1.011 ms  1.029 ms
 5  138.197.249.217 (138.197.249.217)  1.040 ms  1.040 ms  1.039 ms
 6  igblmdistc7504.uk.msft.net (195.66.224.140)  1.985 ms  1.450 ms  1.495 ms
 7  ae26-0.icr02.lon24.ntwk.msn.net (104.44.239.107)  2.372 ms  2.369 ms  2.360 ms
 8  be-122-0.ibr02.lon24.ntwk.msn.net (104.44.21.117)  111.969 ms  111.990 ms  111.982 ms
 9  be-6-0.ibr02.dub08.ntwk.msn.net (104.44.30.59)  11.718 ms  11.710 ms  11.736 ms
10  ae124-0.icr03.dub08.ntwk.msn.net (104.44.23.173)  11.596 ms  10.970 ms  11.214 ms
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * *^C
at the same time:
# telnet 104.47.11.74 25
Trying 104.47.11.74...
Connected to 104.47.11.74.
Escape character is '^]'.
220 DB5EUR02FT030.mail.protection.outlook.com Microsoft ESMTP MAIL Service ready at Mon, 21 Nov 2022 08:30:46 +0000
telnet> Connection closed.
So traceroute and mtr are not reliable in such a case.
in order to be deadly sure, you might completely disable firewall and try it again.
Benim tarafımda var:
[kod]# traceroute -I 104.47.11.74
104.47.11.74 (104.47.11.74) için traceroute, maks. 30 sekme, 60 bayt paketler
1 * * *
2 10.80.9.0 (10.80.9.0) 1,073 ms 1,060 ms 1,060 ms
3 138.197.249.104 (138.197.249.104) 1,142 ms 1,143 ms 1,141 ms
4 138.197.251.130 (138.197.251.130) 1,039 ms 1,011 ms 1,029 ms
5 138.197.249.217 (138.197.249.217) 1,040 ms 1,040 ms 1,039 ms
6 igblmdistc7504.uk.msft.net (195.66.224.140) 1,985 ms 1,450 ms 1,495 ms
7 ae26-0.icr02.lon24.ntwk.msn.net (104.44.239.107) 2,372 ms 2,369 ms 2,360 ms
9 be-6-0.ibr02.dub08.ntwk.msn.net (104.44.30.59) 11,718 ms 11,710 ms 11,736 ms
10 ae124-0.icr03.dub08.ntwk.msn.net (104.44.23.173) 11,596 ms 10,970 ms 11,214 ms
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * *^C
[/kod]
aynı zamanda:
[kod]# telnet 104.47.11.74 25
104.47.11.74 deneniyor...
104.47.11.74'e bağlandı.
Çıkış karakteri '^]'.
220 DB5EUR02FT030.mail.protection.outlook.com Microsoft ESMTP MAIL Hizmeti 21 Kasım 2022 Pazartesi 08:30:46 +0000'de hazır
telnet> Bağlantı kapatıldı.
[/kod]
Yani traceroute ve mtr böyle bir durumda güvenilir değildir.
Son derece emin olmak için güvenlik duvarını tamamen devre dışı bırakıp tekrar deneyebilirsiniz.
Hello
I closed it with csf -x but the situation is the same.
