exclude folders from backup in user control panel
psalm91
Do I need to add a file called
/home/USER/.backup_exclude_paths
in user and then add the directories I do not want backup is done?
How is it done?
I searched in google but could not find it
It's easy.
Just create the .backup_exclude_paths file in the /home/user/ directory as you said.
Then exclude the directory's you don't want. They are counted from /home/user/ so add like this:
domains/domain.com/public_html/somedir domains/domain.com/public_html/otherdir
If you want to exclude a backup for example the backups directory in the /home/user directory, exclude like this:
backups
no startslash needed, no end slash there either.
So adding a line in .backup_exclude_paths
like this
public_html/data/my/files
Will exclude the folder files ?
like this
Probably yes. I'm not sure because used like this, it's a symlink, not a real path. If you only have one domain it might indeed work. I've not tested it this way.
If you have more domains you have to specify the domain. And you can get into trouble using it like this, if you have multiple domains in the account and then change the main domain.
Might nog be an issue if you only have one domain and only keep one domain on that account.
For these reasons I always use the full real path instead of the symlink. But ofcourse you can feel free to do it as you like.
Thanks what I want to do is to put this exclude file in the user so yes it involves with that particular domain only
