error message cannot resolve maps.rspamd.com: query refused
hqn34
I installed spamassassin first. Then I installed rspamd. I get error message cannot resolve maps.rspamd.com: query refused in the web interface
i'm having the same issue..
i've tried opening the following outgoing ports, to no avail:
11335,10053,53,11332,11333,11334
i still get the same message (both in the rspamd log, and in the web controller):
Thank you for the help!
Those all work fine here too..
here's a sample from my error log (from the web interface)
11/29/2022, 2:28:02 PM    controller    898787    map    7n3qic    cannot resolve maps.rspamd.com: query refused
11/29/2022, 2:25:32 PM    controller    898787    map    dyatkr    cannot resolve maps.rspamd.com: query refused
11/29/2022, 2:25:03 PM    normal    898790    lua    1d7e68    error querying dns \"214.134.251.185.asn.rspamd.com\" on 127.0.0.1: query refused
11/29/2022, 1:42:28 PM    normal    898790    lua    2c2398    error looking up 204.67.148.104.in-addr.arpa: query refused
11/29/2022, 1:42:28 PM    normal    898790    lua    2c2398    error querying dns \"204.67.148.104.asn.rspamd.com\" on 127.0.0.1: query refused
11/29/2022, 1:33:09 PM    normal    898790    lua    254fa1    error querying dns \"106.126.40.78.asn.rspamd.com\" on 127.0.0.1: query refused
11/29/2022, 1:00:42 PM    normal    898790    lua    bcdd99    error looking up 58.69.162.69.in-addr.arpa: query refused
11/29/2022, 1:00:42 PM    normal    898790    lua    bcdd99    error querying dns \"58.69.162.69.asn.rspamd.com\" on 127.0.0.1: query refused
11/29/2022, 12:45:58 PM    normal    898789    lua    06499f    error looking up 209.120.109.193.in-addr.arpa: query refused
11/29/2022, 12:45:58 PM    normal    898789    lua    06499f    error querying dns \"209.120.109.193.asn.rspamd.com\" on 127.0.0.1: query refused
EDIT:
in /etc/named.conf, i see the following settings:
listen-on port 53 { any; };
listen-on-v6 port 53 { any; };
allow-query { any; };
in /etc/resolv.conf, i have the 2 following entries:
nameserver 127.0.0.1
nameserver 8.8.8.8
i just added this between the 2:
nameserver 1.0.0.1
And when you add the 2 IPs I name it doesn't work either
Address: 151.115.41.123
Address: 88.198.198.21
Mz
i'm sorry, i'm not sure where i should add them..
i tried adding a line to /etc/hosts for maps.rspamd.com
but, clearly, there is a communication problem between rspamd and whatever dns service it's trying to use, because, as you see above, all of its queries keep failing..
Are you sure you are using DA?
If so go to the admin area, extra feature, ConfigServer Security & Firewall, csf tab - Quick Actions - add in the field - Allow IP address , the address I put :
by clicking on Quick Allow to add the 2 IP
oh, ok, i thought you were talking about adding them to the named process, somehow..
So, the canonical address is just in the comment, right?
ok, i just added the addresses to CSF allow, restarted the rspamd process, no joy..
11/29/2022, 5:01:21 PM controller 954942 map qamb1r cannot resolve maps.rspamd.com: query refused
11/29/2022, 5:01:20 PM controller 954942 map k8f914 cannot resolve maps.rspamd.com: query refused
11/29/2022, 5:01:20 PM controller 954942 map 7n3qic cannot resolve maps.rspamd.com: query refused
11/29/2022, 5:01:20 PM controller 954942 map dyatkr cannot resolve maps.rspamd.com: query refused
11/29/2022, 5:01:20 PM controller 954942 map fdp86m cannot resolve maps.rspamd.com: query refused
11/29/2022, 5:01:19 PM controller 954942 map yhcyzt cannot resolve maps.rspamd.com: query refused
11/29/2022, 5:01:19 PM controller 954942 map 1u5hdp cannot resolve maps.rspamd.com: query refused
11/29/2022, 5:01:19 PM controller 954942 map qbq3yk cannot resolve maps.rspamd.com: query refused
11/29/2022, 5:01:19 PM controller 954942 map o33omj cannot resolve maps.rspamd.com: query refused
i got it!!
i just added this line to the file /etc/rspamd/options.inc
nameserver = ["1.0.0.1:10", "8.8.8.8:53:1"];
under:
dns {
    timeout = 1s;
    sockets = 16;
    retransmits = 5;
i guess rspamd doesn't like it that i'm using 127.0.0.1 in my resolve.conf..
EDIT: i thought that was supposed to be a good thing..
EDIT: just changed that line to: nameserver = ["1.0.0.1:5", "8.8.8.8:53:5"];
Is this the configuration, have you tested it?
oh snap!!
Thank You!
You know, i could've sworn i tested it before.. maybe i forgot to add the port number..
I'm gonna settle on this, and be done with it:
nameserver = ["127.0.0.1:53:8", "1.0.0.1:53:1", "8.8.8.8:53:1"];
Thank You again for all your help!!!
i really, really, really appreciate it!!
if you have any suggestions on optimal scoring setup, or any other optimisations, for rspamd, i'm all ears!
Thank you again so much!
PS: just to be 100% clear, there was no nameserver variable in the original config; that's one of the first things i tested, but, obviously, i did something wrong that first time around..
oh snap!!
Thank You!
Thanks to you especially
Darn it!
i started getting errors again on 127.0.0.1!
took it out from /etc/rspamd/options.inc
so now it's just:
nameserver = ["1.0.0.1:53:5", "8.8.8.8:53:5"];
i hope my server doesn't get blocked from these nameservers..
If you want to use 127.0.0.1:53 you should first configure your named to serve as a caching or forwarding DNS. These roles are disabled by default.
@zEitEr, I have another error, probably nothing to do with the topic, but with Redis in the rpamd logs:
2022-++-++ 08:++:++ #2769176(rspamd_proxy) <e81mhc>; lua; lua_redis.lua:1200: cannot upload script to 127.0.0.1:6379: Connection refused; registered from: /usr/share/rspamd/lualib/plugins/neural.lua:201
