libphp7.so undefined symbol: curl_mime_name
MauriceO
After updating PHP Apache won't start anymore
httpd[23207]: httpd: Syntax error on line 50 of /etc/httpd/conf/httpd.conf: Syntax error on line 4 of /etc/httpd/conf/extra/httpd-phpmodules.conf: Cannot load /usr/lib/apache/libphp7.so into server: /usr/lib/apache/libphp7.so: undefined symbol: curl_mime_name
Line 50 of /etc/httpd/conf/httpd.conf
Include /etc/httpd/conf/extra/httpd-phpmodules.conf
Line 4 of /etc/httpd/conf/extra/httpd-phpmodules.conf
LoadModule php7_module /usr/lib/apache/libphp7.so
Did already a new build of apache and php and a rewrite conf.
Anyone an idea how to solve this issue?
php 7.4.33
apache 2.4.54
centos 7
What is your cURL version and did you update to the latest DA version who is not controlling cURL anymore ?
I assume that you have already did yum update curl so try :
 yum update libcurl
I use DA 1.645, which is the latest
There is no update for libcurl at the moment available by yum.
yum list installed | grep libcurl
libcurl.x86_64 7.29.0-59.el7_9.1 @updates
libcurl-devel.x86_64 7.29.0-59.el7_9.1 @updates
The latest version of libcurl is already installed.
yum install libcurl
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.theory7.net
* centos-sclo-rh: mirror.theory7.net
* centos-sclo-sclo: mirror.theory7.net
* epel: mirror.nl.leaseweb.net
* extras: mirror.theory7.net
* updates: mirror.theory7.net
Package libcurl-7.29.0-59.el7_9.1.x86_64 already installed and latest version
Nothing to do
The content of httpd-phpmodules.conf
cat /etc/httpd/conf/extra/httpd-phpmodules.conf
LoadModule ruid2_module /usr/lib/apache/mod_ruid2.so
Mutex posixsem
LoadModule mpm_prefork_module /usr/lib/apache/mod_mpm_prefork.so
This is odd. Can you try this command?
php -m | grep curl
Out of curiosity, are you using PHP 7.3 or another one? Any specific reason not to use php-fpm instead of mod_php?
@zEitEr any clue on how to fix this?
I'm using PHP 7.4
[root@web01 ~]# php -m | grep curl
curl
[root@web01 ~]#
There is no specific reason mod_php is used. Wasn't that previously the default.
After changing to php-fpm, build php again, and rewrite_confs Apache is working again.
While I'm not quite sure on what is wrong here, my best offer would be to switch to PHP-FPM. There is no much sense to use mod_php+mod_ruid2 any longer, as they are about to be removed from DirectAdmin support.
If you still want to use mod_php, then you might try and run
ldconfig
./build php
./build apache
Enter commands in your server console one by one. Checking carefully results of each command, for the case if they report any error.
Correct. But it will be gone so it was better to switch, which is why I asked.
Also with php-fpm it's possible to have multiple php versions running. That makes it a lot easier to switch to newer PHP versions and test before if your site is compatible with it.
If not, you can switch back to the former PHP version, update/fix and then switch to the newer one. If that is working, then at a certain time you can put that as php1 and remove the EOL version.
