I'm a semi newbie for this kind of stuff and a bit poor. Instead of doing by hand I decided to use the $2 DA.
I Installed and update Ubuntu 22.04 and then installed DA without seeing any errors. Looks like it uses php 8.1?
But when I add a index.php page I get this error:
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
At first I thought maybe bad config on wp, etc then I realized when I created a a info php page I could not pull info page. So 100% an error. I found this error page idk if it's the right info:
[Tue Dec 06 02:12:25.943428 2022] [proxy:error] [pid 2922:tid 139625179387456] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php81/sockets/admin.sock (*:80) failed
[Tue Dec 06 02:12:25.943462 2022] [proxy_fcgi:error] [pid 2922:tid 139625179387456] [client MYPERSONALIP] AH01079: failed to make connection to backend: httpd-UDS
As far as I know this means php not working right.
Hopefully someone has an idea. BTW Using Vultr I doubt that matters but I assume their one the top 10 vps out there so I have a feeling it should work but maybe they have a bad image?
Service Unavailable
