JohnnyBravo
- Aug 24, 2018
HI,
I want to update Nginx but can't download the files... what is happening?
Yes but if I download the file with wget, custombuild doesn't see it and still wants to download a file...That file does not exist on that server,
https://files.directadmin.com/services/custombuild/nginx-1.23.2.tar.gz does
./build set_fastest command isn't necessary anymore normally. Just check if your mirror in options.conf is now files.directadmin.com and no other.nginx:1.23.2:Download of https://files.directadmin.com/services/custombuild/nginx-.tar.gz failed, re-downloading the file...
/usr/local/directadmin/custombuild/custom_versions.txt only. So your current file still contain nginx: without a version. In order to fix either remove the complete line from the file, or follow the suggestion from Richard.Should be done automatically on the DA update.Only ClamAV wasn't able to download....
