RumaDaptardar
- Nov 19, 2022
I don't know why there is no update button in my current installed DirectAdmin > Support & Help > Updates
Output of
da update
What should I do ?
I want to update my da.
Output of
da update
Unknown command `update'. Please specify one command of: admin, admin-backup, config, config-set, create-login-url, database-create, doveadm-quota, info, install, license, permissions, root-auth-url, server, suspend-domain, suspend-user, unsuspend-domain, unsuspend-user or version
Usage:
directadmin [OPTIONS] <command>
Help Options:
-h, --help Show this help message
Available commands:
admin Print admin username
admin-backup Perform admin-level backups
config Print Directadmin config
config-set Set Directadmin config value
create-login-url Create single-sign-on URL
database-create Create SQLite database
doveadm-quota Print email usage quota
info Print binary compile info
install Run Directadmin installer
license Print license info
permissions Set Directadmin files permissions
root-auth-url Create a login-key for HTTP API access
server Run Directadmin web server
suspend-domain Suspend domain
suspend-user Suspend user
unsuspend-domain Unsuspend domain
unsuspend-user Unsuspend user
version Print Directadmin version
What should I do ?
