Problem with install LiteSpeed Enterprice
djcart
Hi, after update Clouxlinux installed openlitespeed and We can't change server to litespeed enterprice. Now we can't change version this server:
[root@server ~]# cd /usr/local/directadmin/custombuild
[root@server custombuild]# ./build update
[root@server custombuild]# ./build set webserver litespeed
webserver is already set to litespeed
[root@server custombuild]# ./build set php1_mode lsphp
php1_mode is already set to lsphp
[root@server custombuild]# ./build litespeed
[ERROR] LiteSpeed Web Server is running!
but the system shows that openlitespeed is running
curl: (22) The requested URL returned error: 404
Download of https://files.directadmin.com/services/custombuild/httpd-2.4.29.tar.gz failed, re-downloading the file...
Download of https://files.directadmin.com/services/custombuild/httpd-2.4.29.tar.gz failed 4 times, exiting...
What OS version do you run? What DirectAdmin version do you have?
You ty to download too old Apache. httpd-2.4.54 is the latest. What do you have in custombuild/custom_versions.txt?
I found a bug you helped me find. I saved the content in the version file and not custom_version. Now the installation is successful. thank you
