How to configure extensionless-php on nginx only setup
codingmachine
Hello!
I am attempting to set up extensionless-PHP where you can access a PHP file without the extension.
Example:
https://example.com/file.php could be accessed like https://example.com/file
location / {
        try_files $uri $uri.html $uri/ @extensionless-php;
        index index.html index.htm index.php;
    location ~ \.php$ {
        try_files $uri =404;
    location @extensionless-php {
        rewrite ^(.*)$ $1.php last;
This would be the template I would need to apply, though I do not see where to apply this to a template file.
I know templates are stored in /usr/local/directadmin/data/templates/custom
But none of the Nginx files have a location / {} that I can see
Any help would be appreciated.
Should you need it only for one-two domains, then you'd better customize it in Directadmin interface without modifying NGINX templates.
Hi Alex,
How would I go about implementing it on a domain basis? Where would I go to add this configuration?
Sadly the first link does not apply as I am running an NGINX-only setup.
The second link seems to refer to modifying the template files, but you mentioned that is not recommended if i wanted to just apply this configuration for a single domain.
Where would i find the option to add this configuration within the DirectAdmin interface?
You will be probably surprised if you try and follow suggestions from these forums. :)
The nginx link is next to Apache on a page in Directadmin. The page describes how to find it and gives an overview.
A nginx block in DIrectAdmin is duplicating functionality of Apache blocks. The only difference is in directives (configuration file).
The both links provided earlier are valid and contain replies to your questions.
Apologies!
Totally missed that. That was exactly what I was looking for.
