- Aug 30, 2021
When you receive a message in DA system it means update is already installed.when we receive a hotfix notification, the update is done or we have to manage it ourselves.
9c346bb67f9608714c6bb447ea41b5e2bb9e37bf) with the following improvements:Ha yes, it is more install of wordpress with the manager, big bug.One more update (build9c346bb67f9608714c6bb447ea41b5e2bb9e37bf) with the following improvements:
- Evolution fix for WP automatic login, thanks @MisterM
- Evolution fix for menu customizations, thanks @mikussikus
- Reverted PHP ioncube plugin from 12.0.5 back to 12.0.4, because when used together with opcache on PHP 8.1 it causes CLI PHP invocations to crash, which in turn breaks DA password strength check (PHP script in scripts dir).
I have to understand what @MaXi32, I relate a bug rather incomprehensible, I have to close my "mouth"
1. Log into your DA installation
2. Navigate to Support & Help >> Licensing / Updates
3. On the bottom of the page, change the Update Channel value to STABLE.
4. Click the CHANGE UPDATE CHANNEL button
I forgot to tell you that we also have a visibility bug, when you log in as admin or user on the evolution theme, it seems that the login page shrinks to the top left and is deleted directly.
I rectify my message, it is when we disconnect
Originally, /usr/local/directadmin/custombuild/build update was meant to grab a new list of DirectAdmin maintained applications and their DirectAdmin supplied version numbers for CustomBuild.
Used in conjunction with /usr/local/directadmin/custombuild/build versions to show DirectAdmin maintained applications and their versions. Simply running /usr/local/directadmin/custombuild/build versions may or may not have showed the latest DirectAdmin supplied versions (applications that had updates available). Running /usr/local/directadmin/custombuild/build update and then /usr/local/directadmin/custombuild/build versions would serve to update the available application version updates and show what updates were available.
But in DirectAdmin's infinite wisdom to do away with separate application updates and requiring all of that to be in a DirectAdmin update - /usr/local/directadmin/custombuild/build update served to be useless. Except, they also decided that "people that run /usr/local/directadmin/custombuild/build update are probably wanting an application update list... so let's sneak in a DirectAdmin update with that so that the application list will also update."
Like I said, entirely not a fan of this whole CustomBuild application and DirectAdmin update decision.
4.96 to 4.96-58-g4e9ed49f8 in the CustomBuild custom versions section. But keep in mind once you set a custom version it will stay at this version until you remove version customization.No worries, we should release a second version with all the bugs fixedGood day everyone, we released an Evolution fix (build744951d6db1c3d5b7c4dc91365beeda461a6db9e) to auto-fill DB credentials when creating new WordPress instance. Thanks @MisterM.
/etc/mail to be present on the system, but the dir was removed. Creating missing directory resolved the CageFS create issue and fixed all the problems. Anyone experiencing similar problems please report them directly to CloudLinux support.This is the commit version for 1.644How can I revert to 1.644 via CLI ?
"da update 1.644" or "da update 1.64.4" doesnt work, seems I need the full commit version string. But using dig I get only commits for 1.645, but not 1.644. Where to find the commit strings for older DA versions?
2138cff12eb6d60eec6bde18b2bf38b208f9ae51
