mod_fcgid: error reading data from FastCGI server
zEitEr
Super Moderator
www.poralix.com
Just wonder, whether it's a single specific issue or are we early birds before a mass reports on crashes. Had worked on a report from a customer of mine. They updated a CloudLinux server with Apache and all PHP sites stopped working.
Used software:
- CloudLinux release 7.9
- Apache 2.4.55 with PHP as fastcgi
A fix is not ready for public posting yet, at least the way we used it. Just let me know if you see the same on your end. I don't want to spend more time on writing a fix if it's only a single case.
Symptoms:
- Apache shows a 500 error for all PHP scripts
- Logs show:
[fcgid:warn] [pid 97188:tid 140579530512128] (104)Connection reset by peer: [client 37.xxx.xxx.215:0] mod_fcgid: error reading data from FastCGI server
[core:error] [pid 97188:tid 140579530512128] [client 37.xxx.xxx.215:0] End of script output before headers: index.php
@Zhenyapan Thanks for the interest to the case.
I've checked a list of newly posted threads and none of them seems to be related.
The case I've mentioned in my thread is purely related to fastcgi/suexec on a CloudLinux server. Not too sure whether regular CentOS/AlmaLinux/Debian/Ubuntu/etc are effected here.
And even downgrade of Apache does not help. So my guess is either something changed in CloudLinux of suexec module. Probably it's a bug in the patch from DirectAdmin for suexec:
- /usr/local/directadmin/custombuild/patches/suexec-safe.patch
I see changes to suexec were done by DirectAdmin in the following files:
- configure/ap2/configure.apache
- patches/suexec-safe.patch
1 month ago. Probably that's the root cause of the issue.
Yes, thanks. That's the same case. It seems the patch did not work at least on CloudLinux. I have opened a ticket with DirectAdmin support. Waiting for a reply from them.
hey zEitEr, did you manage to resolve the issue? We are experiencing something similar.
Tried two different approaches. The simplest one is to copy:
to
- custom/ap2/configure.apache
and add the following line:
"--with-suexec-safedir=/usr/local/safe-bin" \
back to the file. It should work for the current version Apache. Not too sure about future releases.
