- Aug 30, 2021
There is slight confusion with the update messages - let me clarify.
Older DA versions would only send message that DA was successfully updated on normal updates (when DA version changes), on hot-fixes no message was sent. Some people wanted to have notification if a hot-fix is released as well so added notification messages for hot-fixes. While getting message on hot-fix release is interesting for some, for others this is just extra noise (because hot-fixes do not bring any new features, it is either fixes that affect just a small fraction of users having specific config or OS or it is new CB versions or installer updates).
In DA 1.647 we are introducing config fields which will allow you to control if you want to get notification or not. This should help reduce the noise while still allowing to get all the notifications if one wants to - https://docs.directadmin.com/change...ve-notifications-for-directadmin-auto-updates
