Amit Verified User Joined Mar 24, 2020 Messages 129 Location India Feb 23, 2023 #1 Hi , I have created reseller account .The Disk Space used by reseller is not updating even after deleting large file?
zEitEr Super Moderator Joined Apr 11, 2005 Messages 15,729 Location www.poralix.com Feb 23, 2023 #2 Hello, It's updated nightly. You might force and update disk usage in directadmin. Step 1 – Login into DirectAdmin as an user. Step 2 – Click Site Summary / Statistics / Logs. Step 3 – Click Update under Setting
Amit Verified User Joined Mar 24, 2020 Messages 129 Location India Feb 23, 2023 #3 The step you provided is for user but I want to update reseller account Disk uses?
zEitEr Super Moderator Joined Apr 11, 2005 Messages 15,729 Location www.poralix.com Feb 23, 2023 #4 Follow step #5 from the section "Disk Usage is showing 0.00 or is too low" - https://docs.directadmin.com/operat...html#disk-usage-is-showing-0-00-or-is-too-low
Z Zhenmue Verified User Joined Sep 2, 2021 Messages 93 May 6, 2024 #5 it's so odd, having the reseller space used updating only once per day s: and if the reseller needs an updated info, it need the admin to manually intervene.
Stije Verified User Joined Dec 13, 2009 Messages 200 Location Anywhere, Netherlands May 6, 2024 #6 Amit said: The Disk Space used by reseller is not updating even after deleting large file? Click to expand... Did you empty the trash? Also a deleted file is not deleted inmediatly if it is really big. You can check it with a lsof command. Like this: Code: lsof -nP +L1 | grep deleted Also sometimes the datataskq has not run yet.
zEitEr Super Moderator Joined Apr 11, 2005 Messages 15,729 Location www.poralix.com May 6, 2024 #7 Zhenmue said: it's so odd, having the reseller space used updating only once per day s: Click to expand... Will it change the situation if you set realtime_quota=2 ? See: https://docs.directadmin.com/direct...width.html#how-is-disk-space-usage-calculated
