- Aug 30, 2021
Done,@xyntanl please open a support ticket for this issue. I would suspect some incompatibility with customizations but it is not a wide-spread problem. With support ticket we will be able to request access to the system and investigate it further.
@SanderJ, this change affects only new sub-domains. All existing sub-domains will continue to use old subdomain document root location.
After sub-domain is created you can change its document root using GUI, but there is no option to control the default document root (for new sub-domains).
After we have customized this the way we want, what file controls/saves these settings?Upgraded Evolution menu customizations page
curl -s -k "$(da api-url --user john)/CMD_SUBDOMAIN?json=yes" --data-raw '{"subdomain":"sub","public_html":"/domains/some-path","domain":"example.net","json":"yes","action":"document_root_override"}'
sub.example.net
owned by account john
document root to be /home/john/domains/some-path
./usr/local/directadmin/data/users/{user}/skin_customizations/evolution/files
directory, where {user}
is account that made the customizations. For example /usr/local/directadmin/data/users/admin/skin_customizations/evolution/files
for main admin account customizations. Copying this directory would be enough to completely copy all customizations.In this example we are changingsub.example.net
owned by accountjohn
document root to be/home/john/domains/some-path
/home/john/domains/maindomain.xyz/public_html
to /home/john/domains/maindomain.xyz/public/web
?We've had a couple similar reports as well.Any updates on the missing menu's for reseller/user levels? We've had multiple reports so far.
It looks like cache somewhere. After a while, the new IP appears in Show All Users screen.Changing server IP by /usr/local/directadmin/scripts/ipswap.sh old-ip-here new-ip-here
After changing, admin Show All Users still shows the old IP in the IP column. While going to each user, the new IP appears there.
Switched to version - DirectAdmin v1.647
still see the same old design menu -
I was expecting the new interface post update -
Plz guide how to get the new menu, tried to reset the menu also but no luck.
I dont think so? Didn't knew there was activation needed.Were you able to activate this interface?
Where did you get the print?I dont think so? Didn't knew there was activation needed.
can you plz guide on the same
