custombuild 2.0 removed after installing the hotfix (V1.646 -> 1.647)
patrickkasie
Een echte Hollander
Dear DirectAdmin,
After installing the latest patch, CustomBuild 2.0 is inaccessible when trying to enter it while logged in as admin. This has happened on all 3 out of 3 updated servers
Logging out and logging in doesn't rectify the issue.
Trying the following commands don't help either:
/usr/local/directadmin/scripts/set_permissions.sh da_files
/usr/local/directadmin/scripts/set_permissions.sh all
Regards!
it completely remove it. Just switch to Evolution Skin or reinstall that plugin again, but you will notice some break change that it doesn't work perfectly with Custombuild binary script.
