Active8
- Jul 13, 2013
My DNF command returns errors suddenly :
However CSF is running
But as said my DNF command run in problems still
tried to remove en install iptables + iptables-libs
Whics correct my DNF error but then my CFS is failing and and trow an blank page in panel
so tried to reinstall csf
build works
File exist error is fine because CSF was already installed
Now my CSF is runing but DNF command is giving error again
already did: dnf clean all
So i am in an loop of an strange error what I dont understand, any help is welcome
dnf update
Last metadata expiration check: 0:00:19 ago on Wed 01 Mar 2023 04:57:23 PM CET.
Error:
Problem: package iptables-legacy-1.8.8-4.el9.1.x86_64 requires iptables-libs(x86-64) = 1.8.8-4.el9, but none of the providers can be installed
- cannot install both iptables-libs-1.8.8-6.el9_1.x86_64 and iptables-libs-1.8.8-4.el9.x86_64
- cannot install the best update candidate for package iptables-libs-1.8.8-4.el9.x86_64
- cannot install the best update candidate for package iptables-legacy-1.8.8-4.el9.1.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
● lfd.service - ConfigServer Firewall & Security - lfd
Loaded: loaded (/usr/lib/systemd/system/lfd.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2023-03-01 17:00:58 CET; 50ms ago
Process: 120542 ExecStart=/usr/sbin/lfd (code=exited, status=0/SUCCESS)
Main PID: 120555 (lfd - starting)
Tasks: 1 (limit: 100434)
Memory: 25.5M
CPU: 542ms
CGroup: /system.slice/lfd.service
└─120555 "lfd - starting"
Mar 01 17:00:58 srv.xxx.com systemd[1]: Starting ConfigServer Firewall & Security - lfd...
Mar 01 17:00:58 srv.xxx.com systemd[1]: Started ConfigServer Firewall & Security - lfd.
sudo dnf remove iptables
sudo dnf remove iptables-libs
sudo dnf install iptables
sudo dnf install iptables-libs
/usr/local/directadmin/custombuild
./build csf
build works
Installing CSF...
################################################################################################################################################################# 100.0%
mkdir: cannot create directory '/etc/csf': File exists
Using configuration defaults
mkdir: cannot create directory '/var/lib/csf': File exists
mkdir: cannot create directory '/var/lib/csf/backup': File exists
mkdir: cannot create directory '/var/lib/csf/Geo': File exists
mkdir: cannot create directory '/var/lib/csf/ui': File exists
mkdir: cannot create directory '/var/lib/csf/stats': File exists
mkdir: cannot create directory '/var/lib/csf/lock': File exists
mkdir: cannot create directory '/var/lib/csf/webmin': File exists
mkdir: cannot create directory '/var/lib/csf/zone': File exists
mkdir: cannot create directory '/usr/local/csf': File exists
mkdir: cannot create directory '/usr/local/csf/bin': File exists
mkdir: cannot create directory '/usr/local/csf/lib': File exists
mkdir: cannot create directory '/usr/local/csf/tpl': File exists
mkdir: cannot create directory 'webmin/csf/images': File exists
mkdir: cannot create directory 'ui/images': File exists
mkdir: cannot create directory 'da/images': File exists
mkdir: cannot create directory 'interworx/images': File exists
cp: cannot stat 'Geo': No such file or directory
chmod: cannot access '/etc/csf/*.cgi': No such file or directory
chmod: cannot access '/etc/csf/*.php': No such file or directory
chmod: cannot access '/etc/csf/*.py': No such file or directory
csf.c:11:1: warning: return type defaults to 'int' [-Wimplicit-int]
11 | main ()
csf.c: In function 'main':
csf.c:21:9: warning: implicit declaration of function 'setenv'; did you mean 'setpwent'? [-Wimplicit-function-declaration]
21 | setenv("CSF_RESELLER", "", 1);
| setpwent
Unit /etc/systemd/system/firewalld.service is masked, ignoring.
Restarting CSF...
CSF installation has finished.
Error:
