Wordpress hardening & nginx config
iworx
Belgium
We're all suffering from those pesky xmlrpc.php hits, wp-config gathering and users "forgetting" to update their Wordpress installs.
You can add the following code to the HTTP Config > nginx config files for users with a Wordpress install to try and keep the bogies out.
It would be nice if the Wordpress pack in the Pro-pack would do this automatically if a WP install was detected.
############ WordPress Hardening Config for nginx ####################
## Based on : https://gist.github.com/nfsarmento/57db5abba08b315b67f174cd178bea88
# Disable logging for favicon and robots.txt
location = /favicon.ico {
  try_files /favicon.ico @empty;
  access_log off;
  log_not_found off;
  expires max;
location = /robots.txt {
    allow all;
    log_not_found off;
    access_log off;
    try_files $uri /index.php?$args;
#Deny access to wp-content folders for suspicious files
location ~* ^/(wp-content)/(.*?)\.(zip|gz|tar|bzip2|7z)\$ {
  deny all;
location ~ ^/wp-content/uploads/sucuri {
  deny all;
location ~ ^/wp-content/updraft {
  deny all;
#Disable execution of scripts other than PHP from your document root
location ~* .(pl|cgi|py|sh|lua|asp)$ {
   return 444;
#Disable access to your configuration files and other files that you don’t want to users are able to see
location ~* /(wp-config.php|readme.html|license.txt|nginx.conf) {
   deny all;
# Disable wp-config.txt
location = /wp-config.txt {
    deny all;
    access_log off;
    log_not_found off;
# Disallow php in upload folder and add webp rewrite
location /wp-content/uploads/ {
    location ~ \.php$ {
    #Prevent Direct Access Of PHP Files From Web Browsers
        deny all;
    # webp rewrite rules
    location ~ \.(png|jpe?g)$ {
        add_header Vary "Accept-Encoding";
        add_header "Access-Control-Allow-Origin" "*";
        add_header Cache-Control "public, no-transform";
        access_log off;
        log_not_found off;
        expires max;
        try_files $uri  $uri =404;
# nginx block xmlrpc.php requests
location /xmlrpc.php {
  deny all;
  access_log off;
  log_not_found off;
  return 444;
# nginx block wpscann on plugins folder
location ~* ^/wp-content/plugins/.+\.(txt|log|md)$ {
  deny all;
  error_page 403 =404 / ;
# block access to install.php and upgrade.php
location ^~ /wp-admin/install.php {
  deny all;
location ^~ /wp-admin/upgrade.php {
  deny all;
# Deny access to any files with a .php extension in the uploads directory
# Works in sub-directory installs and also in multisite network
# Keep logging the requests to parse later (or to pass to firewall utilities such as fail2ban)
location ~* /(?:uploads|files)/.*\.php$ {
   deny all;
# Stop scann for the follow files on plugins folder
      deny all;
# Stop scann for the follow files on themes folder
location ~* ^/wp-content/themes/.+\.(txt|log|md)$ {
      deny all;
#Direct PHP File Access
#If somehow, a hacker successfully sneaks in a PHP file onto your site,
#they’ll be able to run this file by loading file which effectively becomes a backdoor to infiltrate your site.
#We should disable direct access to any PHP files by adding the following rules:
location ~* /(?:uploads|files|wp-content|wp-includes|akismet)/.*.php$ {
    deny all;
    access_log off;
    log_not_found off;
#Dotfiles
#Similar to PHP file, a dotfile like .htaccess, .user.ini, and .git may contain sensitive information.
#To be on the safer side, it’s better to disable direct access to these files.
location ~ /\.(svn|git)/* {
    deny all;
    access_log off;
    log_not_found off;
location ~ /\.ht {
    deny all;
    access_log off;
    log_not_found off;
location ~ /\.user.ini {
    deny all;
    access_log off;
    log_not_found off;
# Deny access to uploads that aren’t images, videos, music, etc.
location ~* ^/wp-content/uploads/.*.(html|htm|shtml|php|js|swf)$ {
    deny all;
# Deny backup extensions & log files
location ~* ^.+\.(bak|log|old|orig|original|php#|php~|php_bak|save|swo|swp|sql)$ {
  deny all;
  access_log off;
  log_not_found off;
#WordFence
location ~ \.user\.ini$ {
 deny all;
# WordPress: deny wp-content, wp-includes php files
location ~* ^/(?:wp-content|wp-includes)/.*\.php$ {
        deny all;
# WordPress: deny wp-content/uploads nasty stuff
location ~* ^/wp-content/uploads/.*\.(?:s?html?|php|js|swf)$ {
        deny all;
# WordPress: deny general stuff
location ~* ^/(?:xmlrpc\.php|wp-links-opml\.php|wp-config\.php|wp-config-sample\.php|wp-comments-post\.php|readme\.html|license\.txt)$ {
        deny all;
# NGINX RESTRICTIONS
# Directives to send expires headers and turn off 404 error logging.
location ~* ^.+\.(curl|heic|swf|tiff|rss|atom|zip|tgz|gz|rar|bz2|doc|xls|exe|ppt|tar|mid|midi|wav|bmp|rtf)$ {
    access_log off;
    log_not_found off;
    expires max;
# Web fonts send expires headers
location ~* \.(?:eot|otf|ttf|woff|woff2)$ {
  expires max;
  access_log off;
  add_header Cache-Control "public";
# SVGs & MP4 WEBM send expires headers - this rule is set specific to ns site
location ~* \.(?:svg|svgz|mp4|webm)$ {
  expires max;
  access_log off;
# Media: images, icons, video, audio send expires headers.
location ~* \.(?:jpg|jpeg|gif|png|ico|cur|gz|aac|m4a|mp3|ogg|ogv|webp)$ {
  expires 1M;
  access_log off;
# Cache css & js files
location ~* \.(?:css(\.map)?|js(\.map)?)$ {
    access_log off;
    log_not_found off;
    expires 30d;
# CSS and Javascript send expires headers.
location ~* \.(?:css|js)$ {
  expires 1y;
  access_log off;
# HTML send expires headers.
location ~* \.(html)$ {
  expires 7d;
  access_log off;
# Security settings for better privacy
# Deny hidden files
# Deny all attempts to access hidden files such as .htaccess, .htpasswd, .DS_Store (Mac).
location ~ /\. {
    deny all;
# Return 403 forbidden for readme.(txt|html) or license.(txt|html) or example.(txt|html) or other common git repository files
location ~*  "/(^$|readme|license|example|README|LEGALNOTICE|INSTALLATION|CHANGELOG)\.(txt|html|md)" {
    deny all;
# Deny backup extensions & log files and return 403 forbidden
location ~* "\.(old|orig|original|php#|php~|php_bak|save|swo|aspx?|tpl|sh|bash|bak?|cfg|cgi|dll|exe|git|hg|ini|jsp|log|mdb|out|sql|svn|swp|tar|rdf)$" {
    deny all;
# common nginx configuration to block sql injection and other attacks
location ~* "(eval\()" {
    deny all;
location ~* "(127\.0\.0\.1)" {
    deny all;
location ~* "([a-z0-9]{2000})" {
    deny all;
location ~* "(javascript\:)(.*)(\;)" {
    deny all;
location ~* "(base64_encode)(.*)(\()" {
    deny all;
location ~* "(GLOBALS|REQUEST)(=|\[|%)" {
    deny all;
location ~* "(<|%3C).*script.*(>|%3)" {
    deny all;
location ~ "(\\|\.\.\.|\.\./|~|`|<|>|\|)" {
    deny all;
location ~* "(boot\.ini|etc/passwd|self/environ)" {
    deny all;
location ~* "(thumbs?(_editor|open)?|tim(thumb)?)\.php" {
    deny all;
location ~* "(\'|\")(.*)(drop|insert|md5|select|union)" {
    deny all;
location ~* "(https?|ftp|php):/" {
    deny all;
location ~* "(=\\\'|=\\%27|/\\\'/?)\." {
    deny all;
location ~ "(\{0\}|\(/\(|\.\.\.|\+\+\+|\\\"\\\")" {
    deny all;
location ~ "(~|`|<|>|:|;|%|\\|\s|\{|\}|\[|\]|\|)" {
    deny all;
location ~* "/(=|\$&|_mm|(wp-)?config\.|cgi-|etc/passwd|muieblack)" {
    deny all;
location ~* "(&pws=0|_vti_|\(null\)|\{\$itemURL\}|echo(.*)kae|etc/passwd|eval\(|self/environ)" {
    deny all;
location ~* "/(^$|mobiquo|phpinfo|shell|sqlpatch|thumb|thumb_editor|thumbopen|timthumb|webshell|config|settings|configuration)\.php" {
    deny all;
I add them in Custom HTTP Configurations > nginx configs > domain > token 4
