Solved Unknown lvalue in php-fpm service
Richard G
Maastricht
I've asked this before, but was with something else so really did not get an answer to this.
Will appear in the log when php-fpm is restarted or apache is restarted which causes all php-fpm services to restart.
Mar  7 19:54:14 server23 systemd: [/etc/systemd/system/php-fpm80.service:41] Unknown lvalue 'ProtectKernelModules' in section 'Service'
Mar  7 19:54:14 server23 systemd: [/etc/systemd/system/php-fpm80.service:48] Unknown lvalue 'ProtectKernelTunables' in section 'Service'
Mar  7 19:54:14 server23 systemd: [/etc/systemd/system/php-fpm80.service:51] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Mar  7 19:54:14 server23 systemd: [/etc/systemd/system/php-fpm80.service:54] Unknown lvalue 'RestrictRealtime' in section 'Service'
Mar  7 19:54:14 server23 systemd: [/etc/systemd/system/php-fpm81.service:41] Unknown lvalue 'ProtectKernelModules' in section 'Service'
Mar  7 19:54:14 server23 systemd: [/etc/systemd/system/php-fpm81.service:48] Unknown lvalue 'ProtectKernelTunables' in section 'Service'
Mar  7 19:54:14 server23 systemd: [/etc/systemd/system/php-fpm81.service:51] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Mar  7 19:54:14 server23 systemd: [/etc/systemd/system/php-fpm81.service:54] Unknown lvalue 'RestrictRealtime' in section 'Service'
Same for php-fpm74 by the way.
Running Centos 7.9, normal Apache.
Just an ignorable issue or what is this?
What specifically is in /etc/systemd/system/php-fpm80.service and /etc/systemd/system/php-fpm81.service?
And also in php-fpm74.service. It's all default.....
They all got exactly the same content except the pid changes to the correct php version.
# php-fpm startup for DirectAdmin servers
# To alter the FPM environment, drop a file with the suffix
# .conf in /etc/systemd/system/php-fpm.service.d, with
#     [Service]
#     Environment=FOO=bar
# To reload systemd daemon after changes to this file:
# systemctl --system daemon-reload
[Unit]
Description=The PHP FastCGI Process Manager
After=syslog.target network.target
[Service]
Type=notify
PIDFile=/run/php-fpm74.pid
ExecStart=/usr/local/php74/sbin/php-fpm74 --nodaemonize --pid=/run/php-fpm74.pid
ExecReload=/bin/kill -USR2 $MAINPID
LimitMEMLOCK=infinity
LimitNOFILE=65535
# Set up a new file system namespace and mounts private /tmp and /var/tmp directories
# so this service cannot access the global directories and other processes cannot
# access this service's directories.
PrivateTmp=true
# Sets up a new /dev namespace for the executed processes and only adds API pseudo devices
# such as /dev/null, /dev/zero or /dev/random (as well as the pseudo TTY subsystem) to it,
# but no physical devices such as /dev/sda.
# CageFS does not work with php-fpm on DirectAdmin servers. The issue is caused by this directive set to true, thus, commented out
#PrivateDevices=true
# Attempts to create memory mappings that are writable and executable at the same time,
# or to change existing memory mappings to become executable are prohibited.
# Commented out, problems with PHP 7.0/7.1 reported
#MemoryDenyWriteExecute=true
# Explicit module loading will be denied. This allows to turn off module load and unload
# operations on modular kernels. It is recommended to turn this on for most services that
# do not need special file systems or extra kernel modules to work.
ProtectKernelModules=true
# Kernel variables accessible through /proc/sys, /sys, /proc/sysrq-trigger, /proc/latency_stats,
# /proc/acpi, /proc/timer_stats, /proc/fs and /proc/irq will be made read-only to all processes
# of the unit. Usually, tunable kernel variables should only be written at boot-time, with the
# sysctl.d(5) mechanism. Almost no services need to write to these at runtime; it is hence
# recommended to turn this on for most services.
ProtectKernelTunables=true
# Required for resource throttling
ProtectControlGroups=false
# Any attempts to enable realtime scheduling in a process of the unit are refused.
RestrictRealtime=true
# Restricts the set of socket address families accessible to the processes of this unit.
# Protects against vulnerabilities such as CVE-2016-8655
RestrictAddressFamilies=AF_INET AF_INET6 AF_NETLINK AF_UNIX
# Takes away the ability to create or manage any kind of namespace
#RestrictNamespaces=true
[Install]
WantedBy=multi-user.targetp
What version of systemd are using?
The ones belonging to Centos 7.9.
rpm -qa | grep systemd
systemd-libs-219-78.el7_9.7.x86_64
systemd-devel-219-78.el7_9.7.x86_64
systemd-sysv-219-78.el7_9.7.x86_64
systemd-219-78.el7_9.7.x86_64
Can be found in Ubuntu man pages:
But not running Ubuntu, I'm running Centos 7.9. However if I can safely ignore them it's fine by me too.
I'm just wondering why they are appearing while I don't have anything configured to use them, just using default Centos 7.9.
That's why I wrote: They are probably OS specific
Directadmin developers knowing that the unknown options in a systemd file don't break anything, prepared an unified config suitable for CentOS and Ubuntu.
If you want to to get rid of them, then customize the files.
Sorry, I misunderstood the "probably OS specific" as that it would be probably specific to the Ubuntu OS. I'm not native English. :)
I rather not customize things if not needed. So if it's just warnings, not breaks anything and I can safely ignore them, then I will do just that.
Ignore them.
Thank you!
Also thank you @sparek for the help.
Ignore them.
Thank you!
@MisterM Sorry, but I don't know what this has to do with my question about the warnings or how?
I know how to exclude updates from yum, but I'm not going to exclude kernel updates.
I never noticed this before, but indeed my CentOS 7 servers are showing this as well.
Safe to ignore.
But if you're looking for an explanation, see - https://raw.githubusercontent.com/systemd/systemd/main/NEWS
RestrictRealtime was added in systemd version 231
ProtectKernelModules, ProtectKernelTunables, and ProtectControlGroups were added in sytemd version 232.
CentOS 7 still uses systemd 219
systemctl --version
And while CentOS (or really RedHat) like to backport fixes - so even though the reported systemd version is 219 you may have features or fixes present in newer versions of systemd - they apparently did not add these directives into the version 219 they are using.
That's the explanation for these "errors". The systemd that CentOS 7 is using doesn't know what these directives are. But systemd just skips over them.
